10-08-2013, 09:47 PM
#16
Originally Posted by smkd13
Alright guys finally got a second to take a picture of the DRL disable mod.
In the drivers footwell right above the gas pedal is the DRL control box. To cut off DRL all you have to do is cut the SOLID BLACK / YELLOW STRIPE wire and that is it. You can wire a on/off switch if you want but it is not needed as this is a disable. (I put the terminal ends on so there is not exposed wire.)
Well, I didn't get to do this today, so hopefully I will be able to tomorrow. I'm also about to post another thread about my rear diff. I ran into some difficulties today.
10-08-2013, 09:52 PM
#17
Real Name: Sam
Real Name: Sam
Originally Posted by 01thunder
i thought the connection was near the battery?
That's probably another way to do it, but I've seen it done this way in many threads.
2001 4Runner Limited 4X4: Whitson Metalworks 3/4 Roof Rack, 199mm Tundra Brakes, Tundra Springs/5100's, OME 890's/5125's, 265/75/16 Bridgestone Revo 2 A/T, SCS F5 wheels & lot's of little mods.
My build thread- http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-08-2013, 09:55 PM
#18
Real Name: Ivan
Real Name: Ivan
i'd rather disconnect something than cut.
2001 SR5,
thundercloud, tundra brake upgrade with 231's, 906's/billies rear, 5100's/stock coils on 4th groove front, ISR/deck plate mod, ford trans cooler mod, 99-00 grille swap, led conversion, 17" 2014 SR5 wheels wrapped with cooper AT3's, 265/70/17
10-08-2013, 09:56 PM
#19
Me too! You never know when you may or may not need them, you know?
10-08-2013, 10:28 PM
#20
let me go take a picture of mine i disconnected (not cut) under the hood. brb....
so on my 2000 limited directly next to the battery on the fender side there is this box with a black metal cage around it, attached to this box is a gray plug with a few wires coming out of them. i disconnected the plug (2 years ago) and its still working (or not working i should say) great.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
10-08-2013, 10:29 PM
#21
Thank you, bro!
10-09-2013, 04:39 PM
#22
Real Name: Ben
Real Name: Ben
Hence why you wire a switch to them lol idk if the 00 are the same as the 01-02 the earlier years are the ones that had the DRL under the hood iirc
10-09-2013, 07:32 PM
#23
Real Name: Ivan
Real Name: Ivan
perhaps toyota changed stuff because my 01 doesn't have that. the DRL relay is under the dash, like the previous post.
2001 SR5,
10-09-2013, 11:33 PM
#24
I don't feel comfortable doing anything until someone who has an '01 just like me tells me how to do it. Until then, they're staying on (ughhhh)
10-10-2013, 11:00 AM
#25
On 2000 model 4Runners, you can unplug the small black box, near the battery in the engine bay, to disable DRLs.
The DRL module on '01-'02 model 4Runners is located under the driverside dash. You just cut PIN 12, which is a black/yellow wire to disable DRLs. You can always install a switch inline to turn them on and off if needed. Write up is on YT: 2002 4Runner: DRL Disable With On/Off Capability - YotaTech Forums
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
10-10-2013, 03:25 PM
#26
Real Name: Eric
Real Name: Eric
i have an 01 and you have to cut the black/yellow wire.
i put a switch inline in case i wanted drls back on
super easy
2001 Toyota 4Runner SR5 4x4
3" SS lift
285/75R16 Cooper Discoverer ATP
Outdoor Logic Front Bumper / Savage Off-Road Rear
Visit my garage for the full list
10-10-2013, 06:51 PM
#27
Well I just successfully did it!
10-10-2013, 07:00 PM
#28
Now do I need to protect the wire with anything in particular? I don't want it to become a fire hazard.
10-11-2013, 11:52 AM
#29
Can always wrap the ends in electrical tape
10-12-2013, 02:42 PM
#30
Real Name: Sam
Real Name: Sam
Yeah, like Rock Slide said, electrical tape, or just do as smkd13 did and put some terminal ends on them so all you need to engage them again is a little wire in the middle.
