Old 10-11-2013, 03:54 PM #16
duffbeer911's Avatar
duffbeer911 duffbeer911 is offline
duffbeer911 is on a distinguished road
I was also getting a loud click through the radio whenever anything electronic turned on. So if I tapped the brake the radio would click. Move the power windows the radio would click ... indicators, headlights, etc etc etc
Not getting any radio noise at all since the new battery went in.
1998 4Runner SR5 V6 3.4
duffbeer911 is offline   Reply With QuoteReply With Quote
Old 10-11-2013, 04:08 PM #17
Limbwalker's Avatar
Limbwalker Limbwalker is offline
Real Name: Scott
Limbwalker is on a distinguished road
Limbwalker's Avatar
Real Name: Scott
heres a good video I used a while back to look for parasitic draws. I dont know if thats your problem, but It sure sounds like something you should do either way with your 'wonky electronics'
How To Perform a Parasitic Draw Test - EricTheCarGuy - YouTube
Limbwalker is offline   Reply With QuoteReply With Quote
Old 10-11-2013, 04:25 PM #18
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by fblainen11 View Post
I am having the same exact problem. Weird noise through the radio and all. Only thing not stock is aftermarket radio. My brother who has installed thousands of radios while working for CC in college was the installer. I would doubt that it is causing any problems.
I'll try to see if the battery is causing it. But I'm getting a weird clicking noise as well. It sounds like a relay clicking on and off when the clamps from the jump cables connect.
Is this with key on or key off? Key on it's normal...key off it's a clue something is not right. I had a drain for two years because Hella made a fog light relay harness with the wires in the wrong holes on the relay plug. This sent the entire current for the lights through the switch and left the relay coil energized 24/7. The lights worked and it was a daily driver so the battery never went dead until I went away for a week by plane. The foglight relay click on connecting the battery led me to the foglight circuit.
No relays should energize (click) when you connect the battery with the key off. If they do, the coil is draining the battery 24/7. Not good. Aux plugs and a few other will energize with key on.
My Backyard Frame Swap
Old 10-11-2013, 06:25 PM #19
fblainen11 fblainen11 is offline
fblainen11 is on a distinguished road
Key off. I have Hellas that do not work. I'll try to see if I can undo that relay. That may be the source as the relay is right next to the battery.
Edit: that may be the relay I am hearing. Still is strange that it will have power and not start huh?
fblainen11 is offline   Reply With QuoteReply With Quote
battery
Battery dead BOSMECH 4th Gen T4Rs 8 07-17-2013 03:58 PM
Dead battery? or something else? tcatl Problems & Warranty Issues 4 09-03-2012 12:23 AM
Dead Battery Help strangler Problems & Warranty Issues 8 09-09-2009 11:43 PM
Dead Battery ron70062 3rd gen T4Rs 6 08-26-2008 03:29 AM
03 Dead Battery?? impulsebrklyn Maintenance/Detailing 4 06-14-2005 11:49 AM
