Old 10-13-2013, 01:31 AM #1
0xfded's Avatar
0xfded 0xfded is offline
0xfded is on a distinguished road
0xfded's Avatar
Fuel Trim, Bank 2, "No Data"
Tooled around tonight doing some data logging, but discovered that my OBDII connection is reporting "NO DATA" for my Short and Long Fuel Term Trim on Bank 2. It even reports that those PIDs are not even supported.
Does anyone know if our ECU separates Bank 1 and Bank 2, or just lumps them together? 1998 5VZ, if that matters.
Everything I've read suggests that a V6 should be reporting Bank 1 and Bank 2. But at the same time, I'd expect some serious complaining from the ECU if there was a Bank 2 malfunction.
(On the upside, at least the Bank 1 trims looked well within spec. )
0xfded is offline   Reply With QuoteReply With Quote
Old 10-13-2013, 04:22 AM #2
19963.4lsr5 19963.4lsr5 is online now
If it had a O2 sensor for each bank I'd expect to see a bank 1, and bank 2.
With only 1 O2 sensor I would not.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 10-13-2013, 09:55 AM #3
EatonKyleH's Avatar
EatonKyleH EatonKyleH is offline
Real Name: Kyle
EatonKyleH will become famous soon enough
EatonKyleH's Avatar
Real Name: Kyle
Hopefully this clears up your confusion. Many V style engines use a total 3-4 of oxygen sensors. The 3 sensor setup would include 1 oxygen sensor at each exhaust manifold (total of 2) and 1 oxygen sensor behind the shared catalytic converter. A 4 sensor set up would typically be found on a true dual exhaust with at least 2 converters hence the additional one behind that other cat. These set ups allow for the 2 separate bank fuel trim readings because each bank (side) is monitored individually.
Again above describes many...probably most V style engines but NOT ALL.
However your 4runner should have a total of only 2 sensors. One in front of the converter and one behind it. This is monitoring both banks (sides) at once because they join before the sensor. Therefore you have only one bank
in scan data and it is totally normal on this engine. I'd be more concerned if you were magically picking up data from the mysterious bank 2 lol.
Pictures of my Junk
EatonKyleH is offline   Reply With QuoteReply With Quote
Old 10-13-2013, 02:41 PM #4
0xfded's Avatar
0xfded's Avatar
Outstanding, thank you!
P0170 Fuel Trim Malfunction (Bank 1) Grapdawg Maintenance/Detailing 3 03-18-2012 11:15 PM
Where to buy 99' SR5 Sprt "Highland" trim package or Mud flap? RadRon26 3rd gen T4Rs 1 05-22-2011 12:25 AM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
Real world "city" fuel mileage for V8? v8pwr 4th Gen T4Rs 11 09-05-2008 07:35 AM
Explain "Computer Controlled Fuel Gauge" Light_Mania 4th Gen T4Rs 5 05-18-2006 10:04 AM
