Old 10-14-2013, 11:37 AM #1
Hydroquest Hydroquest is offline
Hydroquest is on a distinguished road
Replacing 4 Pin trailer wiring with pics
Maybe I haven't searched and found the right thread and/or one thread had missing pictures 'cause it was so old.
Anyways, I want to replace/fix my 4 pin trailer wiring. (I'm a visual learner).
Picture key:
Top Left: "Problem" - 5 wires, brown one is cut. (don't understand why there is 5 on a 4 pin hook up?)
Bottom left: 5 wires coming up through the driver's side floor, green one goes to the passenger side??
Top right: 4/5 wires (brown, red, white, yellow) are connecting behind panel on driver's side?
Bottom right: new part I ordered off amazon. How can I make this work?
I was hoping to un-plug the old connection with the spliced wire and replace it with new piece, (simple fix, right?) but realized I cannot do that.
Thoughts/suggestions/help...
Replacing 4 Pin trailer wiring with pics-photo-12-jpg
Hydroquest is offline   Reply With QuoteReply With Quote
Old 10-14-2013, 12:00 PM #2
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is just really nice the great him is just really nice the great him is just really nice the great him is just really nice the great him is just really nice
Real Name: Isaac
i guess i should of done a write up on this when i did this a couple of weeks ago.
so there are 5 wires because, you have a brake light, a running light, left turn signal, right turn signal, and ground. brown is your brake/tail, white is your ground green is your right turn, yellow is your left turn. hope that helps let me know if you have any more questions.
-i just went down to napa auto parts and bought a vehicle side kit, and cut and spliced it into my factory harness. i swapped mine out cause the dust cover wouldnt stay on anymore, and the sheathing/isolation on the wires was getting old and brittle, and starting to crack. so i wanted a good connection and conduction, and so i replaced it. i made sure my splices were inside the vehicle and i used di-electric grease on all of them along with two layers of heat shrink. then wrapped it in 3/8" loom and silicon self sealing tape. on the portion that is outside the truck i doubled the loom(1/2" over 3/8") and again used silicon tape at the ends -about 6" up the line to keep things weather resistant. i can get pics for you if you want or need.
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Old 10-14-2013, 01:17 PM #3
Real Name: Isaac
Real Name: Isaac
ok ill post up some pics later in the day, got some errands to run but i should be able to get them today
Old 10-14-2013, 03:15 PM #4
thor999 thor999 is offline
thor999 is on a distinguished road
I bought a replacement from the dealer, I believe there is a plug in the rear cargo area over driver side wheel well; just unplug the old one and plug in the new one, $38.00 part but worth it to not connect new wires and all. Correct me if I'm wrong, it HAS been a while! (2001)
thor999 is offline   Reply With QuoteReply With Quote
Old 10-14-2013, 04:02 PM #5
Socco's Avatar
Socco Socco is offline
Socco is on a distinguished road
Socco's Avatar
Picture key:
The old white box you have is a trailer light converter. Why does it have five wires and not four? Its because the truck uses two bulbs for your brake and turn lamps. The trailer only has one bulb that is uses for both functions. The converter makes this happen.
It looks like the new plug you have is basically an extension cord. Do you have a link for that part?
So, without pictures (I know, I'm a visual type as well...)
FROM THE TRUCK TO THE CONVERTOR: Right turn lamp (Green), the Left turn lamp (Yellow), Brake lamps (Red), Tail lamps (Brown) and Ground (White.) Connect these wires to the convertor.
FROM THE CONVERTER TO THE EXTERIOR PLUG: Right turn AND Brake is the Green wire, Left turn AND Brake is the Yellow wire, Brown is Tail and White is Ground.
SOLD!99 SR5 V6 - SS 1.2 Lift, 1" BL, 231mm TBU, LTX M/S2s, Savage Sliders, Skids and Bumpers, Lots of LEDs, 70266 ATF Cooler with 5757 Gauge, Homemade Roof Rack, VHF & CBs, Various Off-Road Goodies
'10 Trail Edition - WeatherBeaters, VentShades, Prodigy P3, TruCool 4589 ATF Cooler, E Rated LTX M/S2s, Booster Seats with a hint of kid puke
'16 Tundra TRD SR5 - ATC Cap, AirLift Bags and WirelessAir Controller, Prodigy P3, LineX, E Rated Defender LTXs
Socco is offline   Reply With QuoteReply With Quote
Old 10-21-2013, 04:17 PM #6
Real Name: Isaac
Real Name: Isaac
IMG_4729 by isaacyocum, on Flickr
IMG_4728 by isaacyocum, on Flickr
IMG_4727 by isaacyocum, on Flickr
thats the wiring i did, im not gonna take it all out of layers or loom it put it in, but it shows where it comes out of the truck at, and yeah its really strait forward...
here is some more info that might be helpful...
Trailer wiring 4 pin help- 3rd gen
Old 12-16-2013, 12:03 PM #7
4runnerBoa 4runnerBoa is offline
4runnerBoa is on a distinguished road
Help
Hi guys, I'm new to this forum, but I found this trailer wiring guide to be incredibly helpful to me when I had to change out the wiring connection in my 98' Escape. It covers the basics of wiring as well as common problems:
Trailer Wiring Diagram Guide - HitchAnything.com
4runnerBoa is offline   Reply With QuoteReply With Quote
4 pin , trailer wiring , wiring
Trailer wiring 4 pin help- 3rd gen Ron Helmuth Engines / Suspension / Wheels / Tires / Audio / Accessories 25 02-20-2020 04:47 PM
trailer wiring Lil Red Yarder Classic T4Rs 5 05-03-2011 12:29 AM
Wiring for trailer Whackmaster 3rd gen T4Rs 0 11-15-2010 11:27 PM
Help with trailer wiring trd_4runnin 3rd gen T4Rs 5 11-29-2008 07:37 PM
Trailer Wiring ejo4r 4th Gen T4Rs 1 04-07-2005 08:26 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
