10-14-2013, 05:49 PM
Real Name: Robert
Real Name: Robert
How fast can I go in 4WD?
Just curious how fast I can go in "All-wheel drive mode". I say AWD, meaning that it's in 4wd with the center diff unlocked.
I had it in 4wd with center diff unlocked, and forgot to take it out. I merged onto the interstate, and at 60mph, I realized that I never put it back to 2wd. I put the transmission in neutral, clicked the 4wd button, it went back to 2wd, and put the shifter back in Drive.
How fast can I (safely) go with the center diff unlocked?
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
10-14-2013, 06:04 PM
Real Name: Robert
Real Name: Robert
Originally Posted by Singtoe
your safe at any speed. Conditions permitting.
I thought that might be the case, but wasn't sure.
I think Toyota uses this same transmission in other vehicles that have full-time 4wd?
10-14-2013, 06:09 PM
fyi you dont need to shift it into N when you pushed the 4wd button. your safe to push it on the fly as long as your wheels are not spinning at different rates. say sliding.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
10-14-2013, 06:20 PM
Real Name: Isaac
Real Name: Isaac
top speed is warp speed
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
10-14-2013, 06:36 PM
This is a nice feature of the 4Runner and I used it today.
Does this button enable 4H and if so how come it's not the same for 4L ?
10-14-2013, 06:39 PM
The 4WD button means that the transfer case is engaged to put power to the front and rear tires (2WD being just the rear).
The transfer case shifter (which has 4H - N - 4L) changes the gearing on the transfer case so you can crawl slowly with lots of torque but not much speed (4Lo) or not modify the gearing at all (4Hi) for less torque but a higher speed range.
So yes, the button engages 4Hi so to speak since you have to be stopped to shift into 4Lo and the truck will automatically engage 4WD even without the button depressed (unless modified).
And for the record, keep in mind that a conventional 4WD system has the front and rear driveshafts spinning at the same speed (which you shouldn't drive on grippy surfaces like that) and if you have the AWD system (2001-2002) then the 4WD button is really an AWD button until you lock the center differential (orange light in middle of the 4WD indicator is lit).
10-14-2013, 09:55 PM
When the 3rd gen 4Runner was making it's debut, Toyota stated that it was governed to 106 mph. Aftermarket add-ons that hurt aerodynamics like roof racks, lifts, and/or heavier oversized tires will reduce the chance of reaching the governor.
So I'd say something less than 106 mph.
10-14-2013, 10:12 PM
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
I think you mean ludicrous speed
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
10-14-2013, 10:48 PM
Real Name: Isaac
Real Name: Isaac
nope i ment warp speed, as in he is gonna start warping parts by driving fast with them, when they were ment to be used at slow speeds...
10-14-2013, 10:56 PM
Real Name: Scott
Real Name: Scott
on asphalt, its not great. I mean its not a AWD Subaru, BUT after plowing snow for 19 years and beating the hell out of 4x4 trucks and spending a VERY long time in 4H on snowy AND wet to dry roads? You probably didnt hurt anything. Itll live
10-14-2013, 11:06 PM
What about plaid?
10-14-2013, 11:19 PM
A speed most of us can only dream of hitting *Sigh*
I once hit 98, Then the hill turned into a flat road....
10-15-2013, 12:30 AM
Mine cuts out at 108mph, I bet i could get 120-125 out of it on the right straight away if it wasn't limited. The red truck couldn't get past like 102, this one has way more balls, i can only assume it was maintained better.
10-15-2013, 12:45 AM
Is that on the speedometer, or a GPS? A bit of speedometer error is common on non-certified (read not law enforcement certified) speedometers. GPS would be the most accurate method of speed measurement for civilians.
At any rate, that's what the Toyota Engineer stated in the article I was reading, back in 1995. He stated it was a tire integrity speed limit.
But he also stated that it wouldn't run much faster anyway, as the amount of horsepower needed to push the stock truck through the air at that speed, was pretty close to a the maximum horsepower the 5VZ-FE was capable of producing.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Help!! Fast!
mikey's2010SR5 |
5th gen T4Rs |
20 |
07-08-2012 03:37 PM |
I need help fast...
kittinkaboudle |
3rd gen T4Rs |
12 |
11-22-2011 12:54 PM |
How fast
DC Dude |
4th Gen T4Rs |
42 |
11-17-2010 05:23 PM |
Need Help Fast PLEASE
jeremysoca |
4th Gen T4Rs |
29 |
03-24-2005 11:35 AM |
