10-27-2013, 05:04 PM
Real Name: chris
Real Name: chris
Stuck oil filter....
So I went and picked up some oil and an oil filter yesterday, did an oil change right when I got home drained it, and then realized I couldn't get the filter off for the life of me. The truck was hot so I figured that's why, but I needed it right away so I dumped some fresh oil in and dove it. I figured I'd get the filter off when I can let it cool.
How much oil you figure is going to drain out with out draining the oil first? If any? I figured it will all settle in the pan.
10-27-2013, 05:32 PM
Real Name: Kevin
Real Name: Kevin
You won't lose much oil at all. Think about where the oil sits on the dipstick when it's in the tube. That's the level your engine oil sits at when the motor isn't running.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
10-27-2013, 06:03 PM
Real Name: chris
Real Name: chris
That's what I was thinking. If it's cold there's no oil pumped up top.
10-27-2013, 07:33 PM
The best way to remove a tough filter is to drive a long screwdriver all the way thru it and then twist it off.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
10-27-2013, 07:49 PM
^^^exactly what he said...or u could try those rubber pad things that ppl use to open jars, that also works well for grip
3 toy p/u 4x4s sold
2 gen 2 4runners 4x4 sold
00 4runner 5spd 4x4 s/c sold
2014 4runner sr5 2wd current
2014 tacoma sr5 4cyl 4x4 current
10-27-2013, 07:54 PM
I use a filter strap wrench. Owned it for at least 20 years now. Worked on everything but the trans filter on my brothers satty.
Driving a long thick screwdriver didn't do it. But the screwdriver AND the strap wrench did.
10-27-2013, 08:00 PM
Real Name: Keith
Real Name: Keith
Because the oil filter on my 3.4 engine is not easy to access, I decided to use K&N oil filters. They come with a 1" simulated bolt head on the top. Yes, they do cost more.
10-27-2013, 08:16 PM
that's a fun-looking dog in your avatar.
10-27-2013, 08:25 PM
Real Name: chris
Real Name: chris
Yeah, I have used those on other cars. Sounds like a good investment.
I just went out and it's still not coming off. I'm going to wait tell first thing in the morning to get it, but it doesn't get to cold in northern FL. If that doesn't work I'll have to wait tell Wednesday that's the next time I can be with out my 4runner.
When you drive a screwdriver in are you going from the side or through the top of the filter?
10-27-2013, 08:30 PM
Through one side and out the other.
Because you can go thru the wheel well, i use a cup type filter wrench with a ratchet and a long extension. Once I break it loose, I'll slip a baggie over the filter and catch the oil draining out. Continue to unscrew the filter until it drops into the baggie. Done right, there's no mess to clean up.
10-27-2013, 08:33 PM
I have used this one from Lisle with good results, even when the screwdriver did not work:
Amazon.com: Lisle 63600 Oil Filter Tool: Automotive
Try removing it when the engine is at operating temp, not stone cold. Wear some long chemical gloves.
10-27-2013, 10:14 PM
this is exactly what I have
10-27-2013, 10:38 PM
Real Name: Robert
Real Name: Robert
Did you forget to lube the seal of the oil filter, and that's why it's stuck on there?
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
10-28-2013, 09:20 AM
Real Name: chris
Real Name: chris
Yeah I'm going to pick one of these up.
10-28-2013, 09:22 AM
Real Name: chris
Real Name: chris
Nope, I always lube up before I screw something......
