Originally Posted by amalik
hey guys,
when re-filling an empty radiator (in my case because its a brand new one)... i've read that you should keep the cap off and run the engine, watch the coolant get 'sucked in' (circulate around) and cap off as needed.
How long can I run the engine with the cap off? I thought that is a major risk (Boiling coolant shooting out of cap, etc) -- and also when doing this procedure should the heater be running?
thanks much for any replies, i plan to finish this today.
it cant build pressure with the cap off, you can run it as long as you need. you may loose a little bit of coolant, as it heats up, and burps the air out of the system.
just top it off once its done.
sometimes they get air pockets trapped inside, and it takes several heating/cooling cycles to get all the air out.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
