Old 10-31-2020, 01:49 PM #1
Dezerts10 Dezerts10 is offline
Dezerts10 is on a distinguished road
Passenger side motor mount removal
What is this and can I take it off to help get some room to remove motor mount? I assume the bolt above it holds it in place?
Edit: that is a block coolant drain petcock type thing the bolt above it open the port.
Dezerts10 is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 02:37 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Why are you removing the motor mount bracket off the block? You can remove just the motor mounts with the right tools. For that 17mm nut that bolts the motor mount to the motor mount bracket, a 120 click point 3/8" ratchet is super helpful and basically makes it possible to get out.
Old 10-31-2020, 03:01 PM #3
Cause I’m replacing them with these from solid-Offroad.com
Old 10-31-2020, 03:12 PM #4
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Ah, I see. If those are poly bushings in those mounts, you're going to get crazy vibrations and noise into your cab. I have Trail Gear poly mounts for the the 22RE engine in my 85 4runner and it's louder than shit and sends engine vibrations into the frame rails. You might quickly learn this was a big mistake unless you plan on cranking your stereo everywhere you go.
Old 10-31-2020, 03:23 PM #5
Got it, pry bar and some choice words, driver side I’ll try to take it apart at the 17mm bolt first
Old 10-31-2020, 03:25 PM #6
No radio, minimal interior and I play in the desert with my rig, whoops and occasional jumping. It’s not a daily driver so not terrible worried about noise or vibration but I’m sure it will be more noticeable.
Old 11-02-2020, 06:28 PM #7
@ I watched your video and ended up ordering the 120 click gear wrench ratchet you used and I’m going to attempt to change the driver side out this coming week starting with removing the 17mm nut and frame side mount.
Old 11-04-2020, 01:52 AM #8
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You'll love the ratchet. I own them in all sizes. Total game changer.
Old 11-04-2020, 08:58 PM #9
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
do you have a link to those mounts? solid-offroad.com doesn't bring up anything for me.
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 11-08-2020, 09:20 PM #10
Search Instagram for them. I’m not sure if he had a website.
Old 11-08-2020, 09:21 PM #11
I can get it in the hole and on the nut but my motor mount flexes to much to ratchet. I need to get my dad or another hand next weekend to help me.
Old 11-15-2020, 03:09 PM #12
I dunno how to post a video but the reason everything flexes so much is my actual motor mount was broke at the block. Fun stuff
Old 11-15-2020, 04:08 PM #13
Bottom ears on the stock motor side of the mount were broken off, wonder when that happened...? Or wonder how long it’s been broken haha.
Old 11-24-2020, 12:04 AM #14
Well something isn’t right... driver side doesn’t line up even close at the perch. Not sure what’s bent or tweaked but next thing to try to do is loosen passenger side and put the driver side on first
Old 11-24-2020, 09:44 AM #15
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You might try loosening the trans mount as well
bolt , holds , motor , mount , passenger
Passenger side Mount options guitarsail 5th gen T4Rs 4 07-01-2018 11:32 PM
3VZE vacuum leak on passenger side at rear of motor kc15842 Classic T4Rs 2 09-24-2016 10:44 PM
Passenger side fender removal?? SLAMEL 4th Gen T4Rs 0 05-24-2015 03:02 PM
passenger side torsion bar removal 86 4runner swerks Classic T4Rs 0 04-20-2007 06:07 PM
Spark removal on '98 3.4v6 passenger side? 984gunner Maintenance/Detailing 15 02-15-2004 10:27 AM
