11-08-2013, 03:26 PM
#31
Originally Posted by txbonds
Yeah, it is. It's all these parts they use driving it up.
Forged Piston Set (Your Choice of Compression Ratio)
Custom Forged Crankshaft
Chromoly Crossbeam Connecting Rods
Oil Pan & Pick-Up Tube (Installed on Block)
Fully Machined Block
Completely Balanced Bottom End
New OEM Main Bolts
ARP Head Studs
Timing Belt & Timing Belt Tensioners
Lower Belt Covers
Brass Freeze Plugs
New Water Pump
New Oil Pump
For the HP goal you mentioned, that would be a great starting point.
If you still want to rebuild your engine, I'd use that parts/ procedures list as a guide. With the 5VZ-FE being a bi-metal motor, it can be a bit more finicky to seal. With higher HP goals in mind, especially so.
At a minimum use a quality MLS headgasket, with the block properly decked for absolute flatness, as well as the heads, and make sure the RA number finish on the deck and heads is appropriate for the MLS gaskets.
At the very least, use new headbolts, but the ARP head studs as listed above, are preferable.
Depending on what your time is worth, and how badly you want to get involved in the rebuild, I'd give strong consideration to just buying that complete short block you listed.
When it comes to performance, you can have cheap, or you can have good.
11-08-2013, 04:18 PM
#32
don't see me ever doing it given the cost. Just something fun to think about.
17 Jayco Precept 35UP Motorhome - 18 Jeep Wrangler JLU - current
16 4Runner TEP KDSS - 15 4Runner Trail KDSS 4x4 - 06 4Runner V8 4x4 - ALL SOLD
97 4Runner Ltd. 4x4 - SOLD - http://www.toyota-4runner.org/3rd-ge...d-project.html
11-08-2013, 04:40 PM
#33
Sorry, I thought I'd clicked the multi-quote function, and intended to address the OP, with your post as a good suggestion.
Busy day at the track, I should stop lurking here.
11-09-2013, 09:22 AM
#34
You are correct. I will be completely re-doing this motor the right way. That includes ARP head studs and all. I want this to be done right.
11-09-2013, 11:10 AM
#35
Real Name: Kevin
Real Name: Kevin
I've got nothing to add, just posting to subscribe. Lots of good info here guys, keep talking!
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
11-09-2013, 04:05 PM
#36
I take it this is sarcastic...
11-09-2013, 04:20 PM
#37
head studs
I know that your planning on running an SC on this engine but let me remind you that if you use studs it could be an issue removing the heads later on if something down the road happens,i would suggest just using new head bolts or ARP if it's available.Just my 2 pennies.
11-09-2013, 04:59 PM
#38
Real Name: Kevin
Real Name: Kevin
No, not at all. Sorry if it came across that way?
There's not near as much info on the site on rebuilding the 3.4 as there is on my 22RE, and it's something I'm going to have to do sooner or later, so I like these threads. I want to know where the best rebuild kits come from, and I want to hear about mistakes people have made or things that make it easier, I love these threads. No sarcasm at all, I promise.
11-09-2013, 11:24 PM
#39
I said studs, what I meant was new head bolts. Sorry for the confusion. ARP doesn't make any for the 5VZ but LC Engineering does make a kit for the 5VZ.
Sorry man. Didn't mean any disrespect, just wasn't sure what your intentions were. Rock on.
Seems as if we are looking for the same things from these types of threads. I'm open to all types of opinions from people. The more the better!
11-10-2013, 12:56 AM
#40
This comment surprises me. No offense intended, but what issues would head studs present, when/if removing the head(s) later on?
I've removed and installed a lot of Cylinder Heads over the years, that were retained by head studs. Numerous high-performance street car, and Motorcycle engines, and far more insanely overpowered racing machines, I've never had or heard of an issue solely due to head studs.
Reason: Removed pic that was blowing thread waaaaaaaaaaaaay out
11-10-2013, 09:27 AM
#41
I don't see an issue with this either? Please explain.
The only head stud kit I could find is from LC Engineering. Here it is.
Pro Head Stud Set - 5VZ
10-14-2017, 07:29 PM
#42
how are the engine tech gasket kit by the way?
06-13-2021, 01:36 AM
#43
How long ago did you replace your timing belt? If it is worn you can see loss of compression and power.
06-13-2021, 08:25 PM
#44
This is an old post and this advice is bad. Not trying to be mean but the thread posters are likely long gone. A worn timing belt will not cause a loss of compression or loss of power unless it is worn to the point that the engine has jumped timing a few teeth or has so much play that the engine is effectively out of timing.
06-14-2021, 11:24 AM
#45
Real Name: Patrick
Real Name: Patrick
That's not how that works with these motors.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Rebuild or buy a new one?
1987*4runner |
Classic T4Rs |
3 |
01-18-2012 09:19 PM |
rebuild or fix
90 t4r |
Classic T4Rs |
2 |
01-14-2011 04:05 PM |
3.4 rebuild
rubbman |
3rd gen T4Rs |
2 |
09-02-2010 01:31 PM |
3.0 rebuild
Integraholic |
Classic T4Rs |
4 |
10-27-2009 06:46 PM |
rebuild
rubbman |
3rd gen T4Rs |
2 |
01-19-2009 12:46 AM |
