12-30-2005, 06:20 PM
#1
Member
Member
Front end collision help
I originally had this posted in the now hijacked "Front bumper" post. That brought no help, so I will try again.
Took the babegetter out of 4x4 while on the interstate (very stupid) in 3-4 inches of falling snow. Lost traction at 35 mph and went down a 10 foot divider and T-boned the guard rail. VERY close to rolling it over.
I have priced the lower valance on ebay for around $85. Is this an easy unscrew....remove....install, do-it-yourself job? Any help would be great.
A local estimate was $390, including the new bumper brackets because it is bent a few degrees up. I landed on the guard rail from above causing the bumper to bend.
Someone posted a toyota parts website, (I lost it) that had detailed pics and diagrams of body parts to purchase........anyone have it handy??
__________________
Black 2000 4x4 SR5 - 176k miles
12-30-2005, 11:03 PM
#2
Junior Member
Junior Member
ok, basically you can get the aftermarket valance it wont be that much different in my opinion.
As far as the install, you'll want to get in behind the fender liner you'll have 2 10mm bolts on both side on the 90 degree bracket.
Then under the bumper on the 2 big reinforcement brackets you'll have a total of 4 12mm bolts I believe.
After that the chrome bar and valance come off. Then along the joining of the chrome bar and the valance you have a multitude of 10 mm bolts to undo. More than likely they'll be rusted so you might have to soak them down. All together there might be 8-10 of those I think. Aside from that it's a fairly easy install.
If you need any more help i'd be glad to any way possible.
12-31-2005, 08:41 PM
#3
Member
Member
Re: Front end collision help
personally, i would just leave it alone. it's just scratches right? and barely any dent? to me, i wouldn't even know it got hit from 5 ft away. besides the white scratches. but good luck with that.
01-01-2006, 04:33 PM
#4
Member
Member
It's true, I could leave it as is.....that would fit my budget well.
When I hit the guard rail, I thought for sure the whole front end including the hood was toast........I was amazed what little damage it caused.
But, it's going to be fixed....I feel guilty.
bmay: Thanks for the insight, when I get to fixing it I will probably need some help....As far as the aftermarket valance, do you think they come with the fog light filler caps, screws and the seal strip that appears to be there?
__________________
01-03-2006, 08:34 PM
#5
Junior Member
Junior Member
it's been awhile, but I dont think it comes with any of that. Basically you just get the valance and you have to transfer the rest over.
but like i said if you need any help just yell.
if you look in the gallery forum you'll see the wrecked 98 i just bought, so I'm going through alot of that stuff.
02-16-2006, 07:51 PM
#6
Member
Member
For $120 I found this frond end mask, that would blend in well with my black 4runner. Maybe a little fruity just to hide the damage...what do you think?
__________________
02-17-2006, 10:24 AM
#7
Senior Member
Senior Member
for way less than repairing it at a shop, id get it painted to match the body color... this will also eliminate the need for lame front end masks.
__________________
2006 4Runner Sport 4wd
XREAS
JVC kw-nx7000 head unit
02-21-2006, 12:20 AM
#8
Member
Member
why not upgrade to a TJM?
and dont go to the dealer, they are the most expensive.
__________________
1996 Maroon Limited
03-06-2019, 08:24 PM
#9
Junior Member
Junior Member
Same
i was in a front collison
03-06-2019, 08:40 PM
#10
Member
Member
did you hit your head?
__________________
2002 Limited 4Runner
2001 Jeep Cherokee
03-06-2019, 09:40 PM
#11
Senior Member
Senior Member
__________________
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
03-07-2019, 08:34 AM
#12
Member
Member
To be fair, it looks like he got into an accident and wanted advice, but instead of just adding his question to an old thread he's necrobumping to reach the post minimum to start his own thread.
__________________
2001 Jeep Cherokee
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
