11-10-2013, 03:56 PM
Where's my fuel filter 97 4runner
Hi, bought a 1997 4runner recently, 4cyl. I'm new to Toyotas, can't seem to find the fuel filter. I looked under the driverside of the car and under the steering wheel area... nothing. Im guessing it housed in this thing under the manifold? if so, man what a horrible place to put that...
11-10-2013, 04:12 PM
On the V6, it's inside the frame rail, beneath the driver's seat. Probably same place on the 4 cyl.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
11-10-2013, 04:20 PM
I think that's your starter...
The above is right for the v6. Not sure about the 4cylinder.
'98 Desert Dune SR5 - 5-speed, sunroof, e-locker.
TRD/LC lift with Bilstien 5100 and Factory LC Rears
Currently 325,000KM's.
11-10-2013, 04:41 PM
Real Name: Isaac
Real Name: Isaac
im pretty sure its in the same place, the fuel lines are the same up to the motor, so it would stand to reason that the filter is in the same location. check the inside of the frame rail under the drivers seat. their should be a smallish round canister with a line coming in one side and going out the other, and a bracket holding it to the frame. that is your fuel filter.
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
11-10-2013, 04:45 PM
Nope, that's your starter, you fuel filter is directly under the intake manifold on the block, black canister, line in each side, worst possible spot.
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
11-10-2013, 04:54 PM
Real Name: Isaac
Real Name: Isaac
welp there you go, 3rz owner as spoken... apparently is in the same spot they put them on the 22re motors... have fun
11-10-2013, 10:13 PM
Yep I found it... its hiding just behind that housing thing, which someone said is the starter. This is going to suck...
11-10-2013, 10:26 PM
Real Name: Kevin
Real Name: Kevin
Yuck. I hate the stock fuel filter location on the 22 motors. I moved mine to the fender first chance I got.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
11-10-2013, 10:39 PM
are you guys sure about this? i thought fuel filter was on the bottom of the truck...
11-16-2013, 03:34 PM
On the V6 it is. On the 4cylinder we just found out it isn't.
11-17-2013, 03:57 AM
if you cant find the oil filter you shouldn't be changing your own oil, bring it to jiffylube
97 4runner 3rzfe 5speed
D44 sky mfg sas
Dual transfer cases
toyo 37s 5.29 locked F&R
York OBA compressor
11-17-2013, 11:06 AM
Real Name: Bryan
Real Name: Bryan
On the 4cylinder its on the driver side in between the intake manifold I believe you need a 14mm to loosen the banjo bolts and a 10mm to loosen the bracket
2000 Toyota 4Runner Base 2wd - Sold
1999 4Runner SR5 4x4 - Tundra Brake Upgrade- 2nd Gen Supercharger - 7th Injector - 32'' BFG KM2 Mud Terrains - ELocker - 4xinnvations Front Bumper
11-17-2013, 02:52 PM
11-17-2013, 03:00 PM
That is definitely the filter, I would disconnect the fuel lines from it before you go any further.
or follow the fuel lines until they hit the actual filter.
11-17-2013, 06:12 PM
Real Name: Bryan
Real Name: Bryan
In red is the fuel filter and blue is the starter for reference
