There goes the Tundra brake conversion. Make sure you have the 13WL calipers. You do need to trim the dust plate a little bit, the rest is just bolt on....HUGE difference I would say..
The disk is in same diameter, but much thicker.
You might have some clearance issues with some of the rims. But if you are running with spacers, you are fine.
