11-14-2013, 01:08 AM
Firewall flex when clutch is pressed
Greetings,
I have a 2000 4runner 5 speed lately I was having to use clutch start cancel button to start it. Today I decided to check it out and noticed the firewall was flexing as I pressed the clutch, I could feel it moving. My buddy said that maybe the firewall had weakened and that we could weld it to prevent flexing.
Do you have have any advice on how I could fix it?
Thanks
11-14-2013, 01:56 AM
I would think the more likely cause is a faulty clutch pedal switch.
215k+ 1997 SR5 manual, e-locker, + stuff
11-14-2013, 02:00 AM
I had the same problem. I just put a self-adhesive felt furniture bumper on the tab where the switch contact hits. I don't know if my firewall flexes or not. I consider the issue resolved.
My Backyard Frame Swap
11-14-2013, 09:02 AM
happen to have a pic?
11-14-2013, 01:24 PM
Real Name: Josh
Real Name: Josh
I had a problem similar to this one in a 92 Toyota pickup. The reinforcment plate the pedal bolted to cracked and was flexing real bad. Took it all off, welded the crack and fixed.
2005 v8 Limited 4wd
11-14-2013, 02:09 PM
This isn't mine. He used a clear plastic foot for electronics gear (see link below). Works just as well. Mine was not a defect (I think), but just would never start after I installed a nice new, thick carpet. From day 1 in 1999, you really had to push it to the limit. So much easier now.
Clutch start switch
11-14-2013, 03:58 PM
Clutch start switch
so why not bend the bracket?
or better yet, just adjust the switch correctly?
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
11-14-2013, 04:26 PM
Switch does not adjust. You would have to lengthen the white post somehow. Building up the contact point was clearly easier.
You could bend the tab, which is part of the pedal not the bracket, but why? It's in a hellish difficult spot to even see, let alone get sufficient leverage to bend a pretty beefy tab. This is a ten second, $0.25 fix. But sure, do it your way--there is more than one way to skin a cat. I don't see any way bending the bracket would help, though.
11-14-2013, 11:42 PM
Thanks, I will check it out this weekend.
11-17-2013, 12:36 PM
Clutch start switch
thanks, that helps!
