Old 11-14-2013, 04:06 PM #1
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
few concerns, need advice
I'm curious if my engine temp is normal, it was 32 degrees out. It usually stays right below the half mark. Also my car idlles between 1000-1500 rpms at a nice steady idle. At cold start it idles higher. Is that normal ?
also I notice on the oil pan, around the oil drain bolt and around rear ac/heat lines some oil. But it looks dirty. Blackish. I check the dipstick multiple times and the oil seems to be where it has been since I changed it. Although I had a bad valve cover gaskets for long time and there is some sludge around the motor. I cleaned a lot but not where I can't reach. Idk from where it can be coming from or if it's old oil, or rain mixing with old oil and dripping down. It doesn't look like tranny oil because it's motor oil color but dirty looking. Should I clean it very very well with engine degreaser Nd see if it shows up again ?
kolelt is offline   Reply With QuoteReply With Quote
Old 11-14-2013, 04:27 PM #2
bpowa bpowa is offline
bpowa is on a distinguished road
Temp Looks normal to me.
With 176k miles. There are bound to be some oil sepage. Small amount of oil loss won't register on dipstick. Unless its physically dripping. What you can do is retorque the bolts thu can come loose over time since they aren't ment to be torqued down hard.
bpowa is offline   Reply With QuoteReply With Quote
Old 11-14-2013, 04:30 PM #3
5vzT4R's Avatar
5vzT4R 5vzT4R is offline
Real Name: Josh
5vzT4R is on a distinguished road
5vzT4R's Avatar
Real Name: Josh
I haven't been in cold weather really with my T4R, but are you sure it was fully warmed up? It should stay about half way. And your idle is to high if its at 1000, in your pic its about 600, that's normal idle. Yes, get some degreaser and clean it all off. You can't find a leak very easily on a filthy engine.
2005 v8 Limited 4wd
5vzT4R is offline   Reply With QuoteReply With Quote
Old 11-14-2013, 05:03 PM #4
Wow I'm stupid. I misread the rpm odometer. It idles at 600 when warm but when u start it in morning when it's cold its at like 1000-1500. I'm sure it was fully warmed up because I was driving on highway for 30,min. Isnt it true that to cold of engine temp is bad ? What bolts should I retourqe ? Any way of checking if rear engine seal is bad ?
Old 11-14-2013, 06:38 PM #5
aeroneer1's Avatar
aeroneer1 aeroneer1 is offline
Real Name: Nick
aeroneer1 is on a distinguished road
aeroneer1's Avatar
Real Name: Nick
That's where my temp sits even on a warmer day on the highway.
2001 Toyota 4Runner SR5
Build Thread
aeroneer1 is offline   Reply With QuoteReply With Quote
Need advice on mileage concerns for 4runner purchase Cory619 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 07-05-2013 09:59 AM
new HID's installed have concerns russr 4th Gen T4Rs 2 08-28-2012 01:50 PM
Concerns about Low miles hamdog 3rd gen T4Rs 12 01-29-2012 03:22 AM
Have new tires AND concerns Aquabear 4th Gen T4Rs 17 11-25-2011 09:22 AM
Mid Mileage concerns? TacticalSR5 3rd gen T4Rs 8 06-28-2011 02:11 PM
