I realize this is an old thread, but seems to be a recurring issue.
On my 2000 4Runner, I had replaced the gas cap less than a year ago with a new Toyota cap (Amazon) just out of preventative maintenance (seemed like a good idea). But recently I starting smelling gas when engine was running near the left rear of the truck, but saw no leaks and I did get code P0440 once, but cleared and it didn't come back. I have read all the posts about rusty lines and charcoal canisters and other expensive problems/fixes, and was sure I was about to spend some money.
However, on a whim, I bought another new genuine Toyota gas cap (again, I had replaced it with a new Genuine Toyota about a year ago). Looking at the new new gas cap, the rubber gasket in the cap seemed slightly thicker (albeit very slightly, but noticeable), and the vent on the inside of the cap looked slightly different than the cap I bought a year ago?? Also, I took a green scrub pad and lightly rubbed the edge of gas filler neck edge where the cap makes contact just to make sure there wasn't a seal issue (there was a little corrosion/dirt on it, but nothing significant). And the 2nd, new new gas cap has solved my problem for the last 6 months.
I don't know if my first new gas cap was a counterfeit, or just a bad run with a smaller gasket, or maybe the rubber shrunk for some reason, or maybe there was a flaw in the vent on the first new cap???
My point is, even if you have replaced the gas cap, make sure there is a good seal, make sure the neck is clean, and maybe try replacing it again (I typically prefer genuine Toyota when it makes sense, but an aftermarket gas cap might be worth a try just to see if it fits different or has a better seal). And don't throw away your old gas cap (it might be better than the new one).
Just my experience.
Lee
