11-22-2013, 10:43 AM
Real Name: Ivan
Real Name: Ivan
fuel consumption
the truck is really getting bad gas usage. i used to go at least a week before fill ups, now i'm down to 4 days! my driving habits haven't changed, truck is well maintained and up to date, etc. i don't know what is going on! there is a constant smell of fuel while the truck is running. no leaks anywhere, but fuel cap when removed is wet under it. fuel cap is new OEM. there aren't any CEL's but i am thinking maybe the vapor canister is bad. i need to solve this problem asap.
2001 SR5,
thundercloud, tundra brake upgrade with 231's, 906's/billies rear, 5100's/stock coils on 4th groove front, ISR/deck plate mod, ford trans cooler mod, 99-00 grille swap, led conversion, 17" 2014 SR5 wheels wrapped with cooper AT3's, 265/70/17
11-22-2013, 10:50 AM
how many miles are you getting from full till your light comes on?
00' 4runner " Batyoda " sr5 thrush glasspack, k&n cold air intake 3' lift,b&m transmission cooler, 265/75/16 gen grabber a/t's!....
11-22-2013, 11:02 AM
Real Name: Ivan
Real Name: Ivan
between 260-270. it's averaging 16.
2001 SR5,
11-22-2013, 11:15 AM
Real Name: Nathan
Real Name: Nathan
It's winter, most parts of the country get poor grades of gasoline for the winter months. It is very common to see fuel economy go down.
Sold the 3rd Gen, someone totaled my 4th Gen. Sold the LT'd Tacoma. Finally got my FZJ80!
11-22-2013, 11:54 AM
I'd almost give my left nut to get those kinds of mileage again..
11-22-2013, 12:27 PM
I have to laugh when I see these threads. I'm like damn, I'm averaging around 13 MPGs.
2002 "Stormtrooper" 4Runner
Tacoma Bilstein 5100s | Eibach/Toytec Springs (Front) | FJ Springs (Rear) | Tundra 13WL Brake Swap | Much More...
Reason: grammer <-- :)
11-22-2013, 12:40 PM
I get around 12-13 mpg, bigger tires and lots of gear... Leave my rig sitting at idle a lot for the temps and family.
I'm lucky to see 200 before I need a fill, it's going to cost a lot to try and get better mpg, I even thought of a motor swap, but it would be around 5 years before it would become cost effective to do anything drastic. For now a new o2 sensor, plugs, filter, cleaned throttle body & maf, lighter weight oil, ect will be the only thing to try, I wouldn't reccomend over inflating the tires but that helps too. I might just add another fuel cell to increase range, will do nothing for mpg.
'16 Super White Trail Premium w/KDSS, Icon stage 2 w/track bar, TRD Pro modified skid plate, TRD Pro wheels, BFG MT 255/80's, 5% tint.
Instagram: Rockyf36
11-22-2013, 12:53 PM
Real Name: Robert
Real Name: Robert
I think winter gas is the problem. Did the bad fuel mileage occur suddenly?
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
11-22-2013, 01:51 PM
Real Name: Ivan
Real Name: Ivan
this week. throughout the spring and summer i was going at least a week before fills. i filled up monday and this morning i had to fill again. 4 days? WTF!?
2001 SR5,
11-22-2013, 02:10 PM
Real Name: Robert
Real Name: Robert
I wouldn't worry about one tank of gas... It's happened to me where I get a tank and for whatever reason, it seems like I burn through it quicker than normal. Could be a bad batch of gas, or maybe your area just switched over to winter gas.
11-22-2013, 02:17 PM
Real Name: Ivan
Real Name: Ivan
i do worry as that's 50+ a tank full a week well less now and i'm unemployed. money runs off quick! but the gas in the US just sucks! so much for high standards. i lived in PR for a while and i had a 4x4 trooper that i drove everyday/everywhere. i would fill for 60 or so and that lasted a week and a half minimum. the fuel down there doesn't have the shit the fuel here does. it smells more pure too.
2001 SR5,
11-22-2013, 02:41 PM
Real Name: KC
Real Name: KC
I'll trade? I got 170 when the light came on.
1999 4runner SR5 - OME 3" | 2" BL | 35x12.5x15 Baja Claws | Kenwood Performance 12 | Alpine 1200 Watt Amp | * In the mail - 4xInnovations Plate Bumper , Cooper STT's *
11-22-2013, 02:53 PM
The 4Runner is not an economy car. It does okay on gas, for what it is. But a wagon body on a truck chassis, is not the formula to use if great fuel economy is your goal.
In your sig you list a lift too. A lift hurts the already poor aerodynamics further, reducing your MPG even more.
As already mentioned, colder ambient temps. and winter-blend gas also hurt MPG.
11-22-2013, 02:54 PM
Real Name: Robert
Real Name: Robert
Like I said... one tank isn't indicative of a problem. Even if you do get fewer miles out of several tanks, it's likely because of the switch to winter blend.
11-22-2013, 08:09 PM
well stated
