11-24-2013, 09:50 AM
Real Name: Robert
Real Name: Robert
Best way to remove exhaust bolts?
I need to temporarily remove a section of my exhaust shown in the picture below. It's the bolts on the 3-bolt exhaust flange right before the catalytic converter. I soaked the area in PB Blaster for a couple hours, then put a 12 point 14mm socket on it. Even with a breaker bar, I couldn't break it loose. The socket keeps slipping. I tried a 9/16" on it as well, but it slipped too. What next? Do I need an impact gun?
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
11-24-2013, 11:11 AM
Location: Stationed in Camp LeJeune, home is Conover, NC
Good luck.
I've had to cut them off before.
Try a wrench, using another wrench as a lever. That might work.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
11-24-2013, 11:46 AM
Real Name: Robert
Real Name: Robert
Originally Posted by Singtoe
try using a 6 point 14mm socket.
12 point sockets are truly worthless except on 12 sided bolts.
Really? I've always had better results with 12 point sockets when it come to grip. I'll go pick up a deep well 6 point while those bolts soak in PB Blaster a little while longer.
Use a propane torch for plumbing and heat the nuts until they smoke. That will expand the nuts and break the rust bond. They should come off easier then
What he said. Use only a 6 point unless you want to round off the nuts.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
11-24-2013, 01:47 PM
Wait....
You have to remove the bolt. The nut is welded to the flange.
11-24-2013, 02:25 PM
Real Name: Robert
Real Name: Robert
Originally Posted by nissanh
Wait....
You sure? It doesn't appear welded to me...
11-24-2013, 02:26 PM
Real Name: Robert
Real Name: Robert
Damn 6 point rounded off the bolts in no time... Looks like I'm going to have to cut them off...
11-24-2013, 02:35 PM
It's a stud and a nut on the bottom. I don't see a nut on top so I assume the stud threads into the flange on the cross-over.
Actually, that looks like a Cali./two-cat exhaust, but same thing:
The nuts are 90179-10070 at the dealer, p/n for the stud is shown.
My Backyard Frame Swap
11-24-2013, 04:15 PM
Real Name: Robert
Real Name: Robert
Thanks
@ TheDurk
. Mine actually is the Cali emissions type. All three nuts are completely rounded off now. Now I gotta figure out how to proceed from here.
11-24-2013, 05:23 PM
Real Name: Josh
Real Name: Josh
Thanks
@ TheDurk
Sounds like a sawzall will be your best bet.
2005 v8 Limited 4wd
11-24-2013, 06:00 PM
I would have drove it till they were hot, then pb blaster then 6 point, the 6 point didnt round them off the 12 point probably did, never heard anyone say a 12 point was better. hmmm
E-Locker, Bilstein 5100,LX 450 Coils, Tundra Wheels Graphite, 33'' Duratracs, 1.5" wheel Spacers, Energy Suspension Sway Bar Links and bushings,Roll Bar, LED's, Sport Hood! XRC 9.5k Comp Winch Custom Mounted, 3rd Row Rumble Seat, B&M Tranny Cooler, Tundra Brakes, 4XInnovations Sliders, Uniden 520XL Pro CB, 4' Firestik.
My Build Thread!!
http://www.toyota-4runner.org/3rd-ge...8-limited.html
11-24-2013, 06:30 PM
Real Name: Robert
Real Name: Robert
6 point for whatever reason rounded off a lot a quicker than the 12 point. I only used the 12 point on one nut, and the 6 point on the other two. 6 point rounded them off almost immediately. For some reason I've always had better luck with 12 point sockets?
11-24-2013, 06:49 PM
12 points are no no for breaking nuts off. 6 point is much better contact and less chance for slip/rounded off the ends.
2016 Toyota 4Runner Trail Edition
11-24-2013, 07:14 PM
How about a pair of vice grips now that you've already rounded them?
17 Jayco Precept 35UP Motorhome - 18 Jeep Wrangler JLU - current
16 4Runner TEP KDSS - 15 4Runner Trail KDSS 4x4 - 06 4Runner V8 4x4 - ALL SOLD
97 4Runner Ltd. 4x4 - SOLD - http://www.toyota-4runner.org/3rd-ge...d-project.html
