11-30-2013, 12:07 AM
Which floor jack
Looking for a floor jack that will lift our 3rd gens by the frame high enough to get the wheels off. My current frame height is about 17" and with the lift will be closer to 20" Most jacks I see in my area only go up to 17". What are ya'll using that isn't expensive (ie. $150 and up)?
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
11-30-2013, 12:21 AM
If you are talking about from the frame on the side then you are not going to find an inexpensive unit that will do that. In all honesty you are going to be looking a pretty expensive and rather large unit to get more than 20" of lift.
I have a 3ton craftsman and it won't reach the frame on most of my rigs, what I do is lift from the axle or control arm to get it up in the air and then use a jack stand under the frame. You will also have to watch for suspension droop as well. That 20" you mention could turn into 25"-30" when you consider what it will take to actually lift a tire.
I have a hi-lift for really serious lifting, but only use it when I can't get enough with the floor jack.
If you are set on a floor jack then you should look into something like this:
Pelican Parts.com - Low Profile High-Lift Floor Jack
but be ready to pay for it... $550
1998 Limited 4Runner, DD and trying to keep it that way.
1988 4Runner, Project in progress
1991 FJ80, the Beast, 10lbs of potatoes in a 5lb sack
1990 Pickup, about to get some needed TLC
11-30-2013, 12:33 AM
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
11-30-2013, 12:37 AM
I use a 4x4 cut to about 10"-12" on my floor jack. Pretty inexpensive.
2001 Sport Edition
11-30-2013, 01:19 AM
Originally Posted by kball
I have a coupon for this jack for $110 that expires 12/01/2013. PM me your email and I can forward the coupon to you if you want to buy it at the store. Or if you want to order it online you can use coupon code 33581850.
11-30-2013, 01:23 AM
I have the same coupon but it's an inside track coupon so if you're not a member you can't use it.
Edit: my bad it was just a regular coupon so anyone can use it!
236K miles
11-30-2013, 01:45 AM
Nice jack, a buddy has one (the one from HF). Just make sure the screw that holds the rod to the jack is not stripped.
arcan, found at costco and northern tool, has a real nice one as well.
11-30-2013, 10:14 AM
Real Name: KC
Real Name: KC
Working at HF, that jack is on sale for like 68 bucks this weekend until sunday. Nation wide, it's in the Black Friday Ad. Just doesn't have the low profile metal end.
1999 4runner SR5 - OME 3" | 2" BL | 35x12.5x15 Baja Claws | Kenwood Performance 12 | Alpine 1200 Watt Amp | * In the mail - 4xInnovations Plate Bumper , Cooper STT's *
11-30-2013, 10:36 AM
The $68 one is a little different. I was deciding between the two and went with price. The $68 jack is a 3 ton and has a lower max height. If memory serves, I think it's 18". I went with it because my truck is bone stock and 18" is more than enough to hoist it at the pumpkin and the front skid to put it on stands. Anything that would need more than that is way beyond what I could do myself at this time, anyway.
11-30-2013, 10:45 AM
Real Name: KC
Real Name: KC
You're correct. Just looked it up.
I still want one, I just think im better served taking the extra time to use a bottle jack and a few 2x4.
11-30-2013, 10:47 AM
I'm glad all of you chimed in on the HF 23" jack. I've been eyeballing it for a long time.The last jack i had was a 4 ton (not HF) that blew it's seals and I couldn't find replacements.
Price is right on the HF one, even before a sale.
2011 SR5 Premium
Blizzard Pearl
5100s, TRD Wheels, 265/70/17 BFG KO2s
11-30-2013, 12:00 PM
I had this same issue when lifting my T4R and I have a regular jack but I found some 12 to jack stands that have a range of 19"-30" for $40 on CL. I just lift my rig from the front crossmember or rear axle. I don't really just jacks alone while working under any car.
'96 4Runner Limited E-locker, ISR mod, deck plate mod, Rear: LC coils with bilsteins, Front: 3" top plate spacer (for now), diff drop, tundra steelies, 1.25 spacer in front, 285-75-16 Nitto Mud Grappler M/T, satoshi grille mod, Demelo Offroad hybrid sliders,
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
11-30-2013, 04:41 PM
Thanks for all the input. I could easily get by without a lift of 20". Just figured some situations it would be nice to have as much lift as possible.
02 Sport
4xI - AED - Savage
11-30-2013, 04:52 PM
I've been waiting for that HF jack to go on sale for a while and this thread prompted me to go get it this morning. For $110 it's a beast!
236K miles
01-19-2017, 11:12 AM
bringing this thread back to life...
will a 2 ton jack suffice or do I need to buy a 3 ton jack?
