12-04-2013, 04:36 PM
#16
official vendor
official vendor
When we bought ours at O'Brien Toyota in Ohio. They had a 99 with 776,xxx miles on it with the original engine and transmission.
12-04-2013, 04:48 PM
#17
Real Name: Robert
Real Name: Robert
Originally Posted by sawguy
I consistently get 20+ with my '97. DON'T use ethanol!
+1 on not using ethanol.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
12-04-2013, 05:05 PM
#18
Anyone get much past 300k on a 3rd gen 4runner?
You went that far and never put a timing belt kit on it?
Edit: to the original poster
12-04-2013, 08:43 PM
#19
Real Name: Ivan
Real Name: Ivan
what do i use? around here, everything has that 10% shit in it.
2001 SR5,
thundercloud, tundra brake upgrade with 231's, 906's/billies rear, 5100's/stock coils on 4th groove front, ISR/deck plate mod, ford trans cooler mod, 99-00 grille swap, led conversion, 17" 2014 SR5 wheels wrapped with cooper AT3's, 265/70/17
12-04-2013, 08:49 PM
#20
Real Name: Isaac
Real Name: Isaac
yeah i have never seen or heard of a timing belt breaking on one of these. what gives out is typically the water pump. and to remove the water pump you have to remove the timing belt...
fyi these are noninterference motors-5vze (v6)
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
12-05-2013, 12:44 AM
#21
My 99 Limited has 383k and still going strong
12-05-2013, 01:25 AM
#22
How long ago was this? Bob from Texas has 750K ish on his '99 Limited. That was the highest mileage one I've heard of until now.
12-05-2013, 01:45 AM
#23
Real Name: Josh
Real Name: Josh
Originally Posted by Supermoney
Yea, I don't understand either.. I do it every take off.
2005 v8 Limited 4wd
12-05-2013, 02:04 AM
#24
Thanks to all the great advice here, chances of making it past 300+ are getting better and better.
I see them on craigslist from time to time. 300+ miles, good compression, no leaks, no smoke.
Thank God something is built right in this world
12-05-2013, 07:05 AM
#25
Real Name: Robert
Real Name: Robert
Guy I worked with had his timing belt break on his T4R 5vzfe. His fault, he never changed it. Had well over 200k+ miles.
12-05-2013, 07:43 AM
#26
I don't think I would ever replace the timing belt on these unless I was already doing something that had me removing it like changing the water pump. If it were an interference motor I would but one of the reasons I bought this truck is because it is a non interference motor.
12-05-2013, 07:52 AM
#27
Sounds to me like he saved over $1000 in unnecessary maintenance since he didn't changed it at recommended intervals. lol
12-05-2013, 09:30 AM
#28
official vendor
official vendor
It was the beginning of August this year. We were told they didn't plan on getting rid of it. They wanted to keep it on the showroom floor to show off.
12-05-2013, 12:36 PM
#29
I have 327,000 and change on mine a 1998 limited and I am in the middle of a complete front end rebuild/re-gear/updated rear suspension/new leather/new lights/roof rack lights etc....somewhere to the tune of 6k or more....I bought it new off the lot and it has been bullet proof with solid maintenance. I plan on keeping this thing forever even when I do buy a new vehicle in 5 yrs or so. Best vehicles on the road!
12-06-2013, 05:42 AM
#30
Real Name: Tyler
Real Name: Tyler
Mine is at 299k and I don't have a problem with it except for some maintenence that was neglected by my grandmother.. But it runs and drives beautifully after the tune up
97 4runner base model - 2.7 auto 5 speed conversion (with transfer case) 2wd - Tundra 17's, General Grabber AT2 265-70-17, TBU, B&M 70268, Toyota mini-header SOLD
96 limited - lc coils/tundra bilsteins, eibach springs/tundra adjustables, isr mod, flipped tow hitch. Many more plans....
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
