Sounds like the switch at the RR door is bad. You should make sure the connections are good of course, but if it works with the Master switch, the motor and wiring are good. You can also swap it with the LR door just to be sure.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
