Old 01-05-2014, 04:48 PM #1
Madizmz's Avatar
Madizmz Madizmz is offline
Madizmz is on a distinguished road
Madizmz's Avatar
Rear end bounce, bounce, Please comment
I've used the search bar. Now thats out of the way.
I have a 2000 sport 4wd sr5. It was recently lifted with the toytec 3 in spacer and bilstein 5100 in front. And ome 891 with bilstein 5125 in rear. We also put a 1 '' diff drop and the pdr-1 panhard drop bracket. At first it rode ok, then started to hear a clunk after about 1 week of driving. Narrowed that down to the front sway bar connecting link, which the drivers side bolt was loose. Tightened it down and it has been ok so far.
I have had this equipment for approx 2 months and I am really noticing that when hitting bumps in the road, especially when the rear wheels are independently taking a pothole or bump that I get a lot of waviness or swimming from the rear. Its very noticeable and it can't be normal for my application(I assume). I've read about the panhard geometry possibly being the culprit. The drop bracket was bolted but not welded. I've checked the bolts and nuts and all are tight. Anyone have any ideas here? Feel free.
I've included pics of the rear tire and rear end. Not sure if they will help.
Thanks.
2000 T4R SR5 Black, 4WD, Toytec lift, Tint, 265/75/16,
Madizmz is offline   Reply With QuoteReply With Quote
Old 01-05-2014, 05:33 PM #2
1985taylor1925's Avatar
1985taylor1925 1985taylor1925 is offline
Real Name: Phil
1985taylor1925 is on a distinguished road
Real Name: Phil
What do you mean by waviness or swimming? I don't know how those drop brackets work since I don't use one. But it seems like it could move around easily with pressure from the panhard bar the way its mounted there. But I cant really tell how it holds there from that picture.
I think you may just be feeling the stiffness of your set up. There has been much discussion on this forum about how much front spacers affect ride quality. A 3 inch spacer is pretty extreme and I'm sure the front end ride quality is suffering as a result. That's also going to tear the cv boots pretty quickly without a diff drop. And for the back, without any weight back there that's a really stiff ride with the 891s. Those coils are intended to hold some weight.
Edit: I see you did install a diff drop, so that's good.
98 - SR5 - 3.4L - 4x4 - Auto - 4:10 gears
http://www.toyota-4runner.org/3rd-ge...my-runner.html
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
1985taylor1925 is offline   Reply With QuoteReply With Quote
Old 01-05-2014, 05:41 PM #3
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Um, get that panhard drop bracket welded. Good bet that's where it's coming from.
Or get a panhard that uses the STOCK mounting location.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 01-05-2014, 06:14 PM #4
Madizmz's Avatar
Madizmz's Avatar
The swimming is like a left to right wave as if you were conducting a symphony - Ha. Kind of describes it though. Your probably right about stiffness but we went with 891's as we heard of 890's sagging over time.
Boots are trashed. Your right.
I'm pretty sure the weld is an issue but I guess I'm curious as to what the weld can do to alleviate this motion... I assume the bracket is swinging left to right? I saw that the bracket should be loose and the rear centered before a weld, is that the process? I'm trying to gather as much info. as possible so I can describe to a tech who I will have do the work as I don't weld.
Old 01-05-2014, 07:08 PM #5
steezemcqueen's Avatar
steezemcqueen steezemcqueen is offline
Moderator
Real Name: Dylan
steezemcqueen will become famous soon enough steezemcqueen will become famous soon enough
Moderator
Real Name: Dylan
The panhard bracket needs to be welded in place. Weld it where it mounts to the stock bracket. That is your problem.
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
steezemcqueen is offline   Reply With QuoteReply With Quote
Old 01-05-2014, 07:28 PM #6
Real Name: Phil
Real Name: Phil
So what doc and steezeman said. That's what I was thinking just wasn't positive. That bracket looks like it can swivel side to side with just that bolt there. As they said you'll have to get it welded. Or you could just remove it all together and revert the panhard back to stock. I have a 3" rear lift and don't run a drop bracket and have never had a single issue. There has been much discussion about that on this forum as well, and many have said the same thing as me . . . its not a part you NEED with a lift 3" or less as a general rule. Your axle will be very slightly shifted without the bracket, but its not enough to really affect ride. You might feel a little side sweeping motion if you hit a big dip at highway speeds
Old 01-05-2014, 07:35 PM #7
Real Name: Phil
Real Name: Phil
Yeah mine tore in a matter of months and that was with a 2" lift. Will you be hauling weight in the back or mounting steel bumpers or tire carriers? If not I wouldn't worry about 890s sagging. Ive been running 890s for almost a year now and got them with 100k miles and they aren't sagging. Maybe over time with added weight. You would definitely have a better ride though. Could also go 99 coils with 1" rear spacer if your not hauling weight often
Old 01-05-2014, 09:22 PM #8
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
Personally I would just get rid of the panhard drop bracket. I don't think you need it with 891's. I have 890's without it and it's fine. If you had LC springs you would probably need it but I don't think 3"'s of lift or less needs it.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 01-05-2014, 09:42 PM #9
Madizmz's Avatar
Madizmz's Avatar
Guess I can't lose by trying without the bracket. I'll take it off, ride around a bit and see how it goes. If it's no better I can always try the welded bracket approach.
I do not plan to get bumpers or more weight constant weight. I do tow a little and attach a dirt bike on a hitch carrier from time to time.
I did not put the lift or bracket on, is this just simply removing the bolts or do I need to jack/support somewhere?
I really appreciate everyone's input. Thanks for your time.
Old 01-05-2014, 11:09 PM #10
xcmtb83 xcmtb83 is offline
xcmtb83 is on a distinguished road
As stated by others is looks like the bracket could be swinging. Delete the bracket, mount to stock location, go test drive. If it is better either leave it attached to factory location or have the bracket welded on. I would recommend jacking in the center of the axle as jacking up on the frame is going to cause your axle to droop and it will be much more challenging to get the bolt to pass though the frame and the end of the bar.
xcmtb83 is offline   Reply With QuoteReply With Quote
Old 01-06-2014, 12:00 AM #11
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
if you decide to delete the bracket all together, then you should get the adjustable panhard bar. lifting or altering right height will shift or move the rear axle from centered to the right/passenger side... the drop bracket is designed to drop the bar back to a lower more "stock" location/geometry. i built my own custom drop bracket and then welded it to the stock mount, it works great and i dont have the issues you are speaking of.
the drop bracket is/was made for a reason, (not just to get you to spend more money either) and its a good reason. it will help with how the vehicle drives and behaves, but yes like the others have stated, simply just bolting it on allows to much "wiggle" room or room for movement(you can not get it tight enough to prevent movement) and that will have a much greater negative affect than even not having the drop bracket. so get that thing welded or buy the adjustable bar -if you ask me id do both, im gonna be buying the adjustable bar from toytec before long to fine-tune my rear axle. having you rear axle centered will prevent your rig from "dog trotting" as you drive down the road, and having the bar fixed and not able to shift side to side, will prevent your "tail wagging" over bumps and make your rig much more controllable especially in the corners.
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Old 01-06-2014, 12:03 AM #12
Real Name: Isaac
Real Name: Isaac
and for heavens sakes man take care of that rust before it eats your rig alive.... hit that crap with the wire wheel and then shoot some epoxy paint over it before
Old 01-06-2014, 12:54 AM #13
JohnsD90's Avatar
JohnsD90 JohnsD90 is offline
JohnsD90 will become famous soon enough
JohnsD90's Avatar
I'm cringing at your rust, glad i dont have to deal with crap anymore (for a few years).
JohnsD90 is offline   Reply With QuoteReply With Quote
Old 01-06-2014, 01:14 AM #14
4x4mike 4x4mike is offline
4x4mike is on a distinguished road
Is your front end higher than the rear? What setting are your 5100's at?
From the side does the truck seem to sit level? The rears will settle over time.
I would park on a flat dry surface, grab a piece of chalk and a plum bob. Hang the string on the inside of the frame rail somewhere near the rear axle. Then hang it on the outside of your tire. Make marks on the ground where the plum bob meets. Do this on the driver and passenger side. The distance should be the same between the outside of tire and inside of the frame rail (or any similar combination) on both sides.
The panhard bar centers the axle under the truck which is important for handling. There are may other factors but as far as the bar and bracket are involved these comparisons are a good starting point. If it's off there needs to be an adjustment.
Did you get an alignment after lifting? If not that can be your problem.
4x4mike is offline   Reply With QuoteReply With Quote
Old 01-06-2014, 07:58 AM #15
Madizmz's Avatar
Madizmz's Avatar
I'm sure that was the intent of the guy that did the work for me. He had a 3rd gen as well and put this same setup on his truck. He said he didn't weld his and had no problems. I doubt it but whatever. I'll take a look at the adjustable bar as well, thanks. Edit- adjustable bar = 199.99! Ouch
Rust? Where? In Maryland that is a new style of paint and undercoating.
The front could be slightly higher but not much. I have the 5100's at the lowest setting.
Thanks for the info. on how to check the alignment of the rear axle, much appreciated.
I did get an alignment after the new shocks.
This forum is a great setup. It seems like there's a bunch of cool guys/gals willing to take time to help. I would buy you a beer or soda if I could but it seems like no one is near Md! Everytime I log in I find something new to twerk on.
Need less bounce. sugjavier 3rd gen T4Rs 29 01-02-2016 10:39 PM
Rear bounce jman11788 3rd gen T4Rs 17 07-04-2012 11:32 AM
Rear Axle Seals - Slight "bounce" when braking erichbean 3rd gen T4Rs 4 03-13-2012 06:22 PM
Rear bounce Tenn_volsfan56 3rd gen T4Rs 12 01-17-2012 03:41 PM
