01-09-2014, 05:54 PM
Location: Mall Crawlin @ 36.1911° N, 44.0092° E,37.7460° N, 119.5329° W
P0300 codes errrrrrrr
Well after doing some reading it looks like I will be getting wires and plugs and possibly the coil packs also. Anything other ideas guy?
P0300- Random Multiple cylinder misfire
P0303- Cylinder 3 MF
P0304- Cylinder 4 MF
Blue
0369
“Be polite, be professional, but have a plan to kill everybody you meet.”
Gen. James Mattis USMC
"AKA Mad Dog Mattis"
01-09-2014, 06:16 PM
official vendor
official vendor
Start by swapping a coil pack to another location and see if the codes change.
01-09-2014, 07:20 PM
I'd say injector, but start with the coil. Depending how old the wires and plugs are, start there.
Some reading:
P0300 P0306 Misfire fixed - fuel injector '99 4Runner
01-11-2014, 01:32 AM
Blue
Totally knew this was you…..errrrrrrr.
01-11-2014, 01:44 AM
Real Name: Ken
Real Name: Ken
I second injectors
P0301 Diagnostic Theory for Shops and Technicians
When the code P0300 is set in the Powertrain Computer, it means that the Misfire Monitor has detected more than a 2 percent variance in RPM between the firing of any two (or more) cylinders in the firing order. The Misfire Monitor constantly checks the rotational speed of the Crankshaft by counting the pulses of the Crankshaft Sensor. The Monitor wants to see a smooth increase or decrease in engine RPM.
If there are jerky and sudden changes in the speed output of the Crankshaft Sensor, the Misfire Monitor begins to count the RPM increase (or lack thereof) contributed by each cylinder. If it varies beyond 2 percent, the Monitor will set a P0300 code and illuminate the Check Engine Light. If there is more than a 10 percent variance, the Check Engine Light will blink or pulse in a steady manner to indicate that a harmful Catalytic Converter misfire is occurring.
Semper Fi!!
Since I retarded from the Corps people ask me what I do??
Install Lift kits and tires/bumpers etc for
Mostly f-ing jeeps
01-11-2014, 01:54 AM
random multi misfire, I'd bank on a tune-up first... but I have actually replaced injectors in a 3rd gen before.
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
01-11-2014, 04:07 AM
Injectors can defiantly do these codes, more likely though (and cheaper to try first too) is Plugs and Wires! pull them all out (individually) and take a look at the insulation condition of the cable!
I just fixed this issue this fall! good luck!
Ill4runner Build
01-11-2014, 10:49 AM
Originally Posted by Kenjan
I second injectors
Thank you for the information. I'll look at the injectors also. All codes point to Cylinder 3&4 so it should be easy to hunt down.
0369
01-11-2014, 06:16 PM
178.00 per fuel injector. Really? Now x that by 6 and the O ring kit from Fel-Pro.
My 4Runner is about to be in the dog house....
0369
01-11-2014, 06:32 PM
Real Name: Instagram: briansd_97r
A lot of threads about major problems with non OEM injectors.
Fightman's thread detailed his woes.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
01-11-2014, 06:38 PM
Real Name: Ken
Real Name: Ken
If u can wait till say Tuesday ill chk the steelership
And my cost
If not u can get rebuilt ones half that
Semper Fi!!
Mostly f-ing jeeps
01-11-2014, 06:40 PM
I know they are pricey, but maybe Camelback is around $150.
Try ohming each one out first, then if you find a dead one, order a new one and the o-rings. Or pull each injector connector with it running (I'd start at cyl 3).
Don't worry about the other five IMHO, unless you have a hefty wallet.
01-11-2014, 06:43 PM
Real Name: Ken
Real Name: Ken
FYI
I'm running oem rebuilt denso off eBay
120 all 6
Shipped
Now have 40ish k on them
Chk out
Shopinjectors.com
Running a set from them in the wife's 300zx
Paid 160 shipped all 6
Also I can dig up I believe I still have a few
From pull apart that ohm out good
Ill send them to ya
Semper Fi!!
Mostly f-ing jeeps
04-04-2020, 02:10 PM
Did you fix the issue? I am getting same code.
01-15-2023, 02:49 PM
I too am having the same issue. Out of the blue my 97 started misfiring, changed out the plugs, no difference, just replace all 3 coil packs a little better but still misfiring P300 code. I'm looking for that magic answer as well.
