Old 01-09-2014, 06:01 PM #1
Aelfwine's Avatar
Aelfwine Aelfwine is offline
Aelfwine is on a distinguished road
Aelfwine's Avatar
2002 4runner o2 sensor output voltage
Hey everyone! Just wondering if somebody knows what the specs are for the output voltage of both o2 sensors. Im just trying to check that everythings working fine on my newly acquired T4R.
So I was playing around with my OBDII and looked at the readings. Its just I've heard that the output voltage should not go above 1.0.
O2 Sensor 1 - 3.25v
O2 Sensor 2 - 0.5v
Checked this at idling 690rpm.
I did not get an MIL by the way.
Aelfwine is offline   Reply With QuoteReply With Quote
Old 01-09-2014, 08:50 PM #2
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Sensor 1 is actually an Air/Fuel Ratio sensor so a 3 volt signal isn't unusual.
Old 01-09-2014, 08:55 PM #3
hambob hambob is offline
hambob is on a distinguished road
To check the O2 sensor you need a scope. But from your readings I'm guessing you have a 2001-2002. These trucks have a A/F sensor for bank 1 sensor 1 and a regular O2 sensor for bank 1 sensor 2. The A/F sensor range is 2.8-3.8v and the O2 voltage range is 0-1v but they are waves and a meter will average it. You have confirmed that its functioning and with no CEL its probably fine. If you had a scope you could see the shape of the waves and that could tell you if you had a bad quality or a malfunctioning A/F sensor or O2.
Hope that helps
hambob is offline   Reply With QuoteReply With Quote
Old 01-09-2014, 08:57 PM #4
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
http://www.autoshop101.com/forms/h37.pdf
Old 01-10-2014, 12:56 AM #5
Aelfwine's Avatar
Aelfwine's Avatar
Thanks guys! Glad to know everythings good with those two)))
JBL Wiring Adapters and Pre-amp Output Voltage jaysapp Engines / Suspension / Wheels / Tires / Audio / Accessories 6 12-03-2014 02:59 PM
2003 T4R voltage output, correct...... videopuppy 4th Gen T4Rs 4 06-29-2011 10:55 PM
Pre Amp Output Voltage on Stock JBL Radio?? sundev2 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-11-2011 07:49 PM
Voltage on the upstream sensor CaleWVU 3rd gen T4Rs 0 02-22-2007 09:45 AM
MAF sensor output type greasefingers Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-11-2005 02:26 PM
