01-09-2014, 11:31 PM
Real Name: Ivan
Real Name: Ivan
intermittent rough idle
park and neutral, no problem. but when in drive and or at a stop, it starts idling a bit rough. then it goes away. could be 2-3 days later, it happens again. no CEL's and all maintenance is up to date. any ideas?
2001 SR5,
thundercloud, tundra brake upgrade with 231's, 906's/billies rear, 5100's/stock coils on 4th groove front, ISR/deck plate mod, ford trans cooler mod, 99-00 grille swap, led conversion, 17" 2014 SR5 wheels wrapped with cooper AT3's, 265/70/17
01-10-2014, 10:43 AM
Moderator
Real Name: The Chosen One
Moderator
There could be an error code stored even though the CEL isn't on, it may be worth having them scanned, especially when it's happening.
'89 4Runner SR5 - stock
01-10-2014, 07:41 PM
Real Name: Ivan
Real Name: Ivan
doesn't have any. i am leaning on maybe a fuel pump or injector or cat going bad?
2001 SR5,
01-11-2014, 04:18 AM
I have had three vehicles with the 3.4 in them. Once you get high in miles the injectors get clogged from bad gas. I sold my first truck because of it. My recommendation first sea foam it and then put a bottle of lucus oil fuel treatment in for a couple tanks of gas. It will work. Report back after you try it.
01-11-2014, 09:25 AM
Real Name: Steve
Real Name: Steve
In intermittent weird issues like that, I tend to lean towards electrical stuff. I'd be looking at MAF values and things like that, which will make it tricky to pinpoint. Usually, in my opinion, if an injector is clogged, it's not sometimes clogged. In my experience, it's usually a chaffed wire that makes intermittent contact with metal or something along those lines and causes your issues. They're a pain in the ass to find, especially intermittent issues.
2003 Silver Pine Lexus GX470- Radflo extended travel/FN BFD’s/Total Chaos/33’s.
01-11-2014, 10:38 AM
Real Name: Ken
Real Name: Ken
TPs air valve
Carbon build up
Also has ur mpg changed just abit??
Chk ur o2 sensors
Could be a buildup n the PCM readjusts the fuel map
Till another build up
Aka--clean ur air intake and TPs system
Semper Fi!!
Since I retarded from the Corps people ask me what I do??
Install Lift kits and tires/bumpers etc for
Mostly f-ing jeeps
01-11-2014, 01:04 PM
Real Name: Ivan
Real Name: Ivan
i have been sea foaming since i bought it, i'll try lucas. i have also replaced and cleaned components; O2's, tps, maf, etc. mpg's are the same as well. i will try the fuel additive first and take it from there. i don't want to take it to the dealer for service for obvious reasons.
2001 SR5,
01-11-2014, 01:08 PM
When it happens is your idle speed dropping to low? Maybe that's why it gets rough. I would think maybe your IAC needs to be cleaned.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
01-11-2014, 01:35 PM
Mine does the same thing but it only does it once in a blue moon
98 limited 4wd.. E Locker, 2.5" lift 265/75/16 toyo mt
06 4runner sr5 2wd
04 rsx type s
01-11-2014, 01:42 PM
Real Name: Ken
Real Name: Ken
Yes that could be it IAC
Rpms dropping to far
Semper Fi!!
Mostly f-ing jeeps
01-11-2014, 02:55 PM
Real Name: Ivan
Real Name: Ivan
no rpm drop.
2001 SR5,
01-11-2014, 05:14 PM
Real Name: Ken
Real Name: Ken
Kinda sounds like ur cat
Does it do it at full chat??
As in wot --pushing hard
Not like bad gas or anything but say when the cruise
Is on at 75 ??
Does it do it at all at first start up?
Or after say 15+ driving
Semper Fi!!
Mostly f-ing jeeps
01-11-2014, 08:44 PM
Real Name: Ivan
Real Name: Ivan
Is on at 75 ??
no to all.
2001 SR5,
01-11-2014, 09:49 PM
01thunder .... i have the same exact word by word problem and i have been searching like crazy all over with no luck... no cods stored or showing. i cleaned
everything that may cause this , sea foam it like three times, tried all the additives .. still no luck.
please update me if you fined the source of the problem.
01-29-2014, 04:20 PM
Real Name: tj hoffman
I'm having a very similar problem, but it happens when I'm in any gear, rough idol, drop in rpms when at a stand still. Not sure what to look at, thinking MAF in my situation but not sure. Very depressing after throwing a grand into a newer tranny.
im young and dumb, but learning quickly, currently have a 1996 "limited" runner, 3inch lift, bilstine shocks and ome coils. Magnaflow 14inch with turn down pipe, custom sound system 150dbs single 18, 230k miles and still going strong
