Old 01-11-2014, 05:27 PM #1
danz danz is offline
danz is on a distinguished road
Need help with temp gauge and broken wire
I have 2 issues that I'm looking for some help.
1. Changing the oil in the car today and while waiting, I discovered 2 wires (see picture) that are broken at the back of the engine facing the firewall. Any idea what is this and how I should fix this? Picture is looking down from the top. There's no room to take a picture from the back.
2. Also, I would be very grateful if someone could provide a picture of the engine coolant temperature sending unit(gauge) location. I had the thermostat replaced with the timing belt job but the temp gauge on the cluster just sits at cold without moving. Heater is working and car runs fine so I think the temp sending unit to the ECU is working. Rest of the gauges in the cluster are working so I think it may be a wire issue or a faulty sending unit.
Anyone?
Need help with temp gauge and broken wire-p1030260-jpg
(SOLD) 2011 4runner SR5 A/T 4X4 Magnetic Grey Metalic, True-Cool LPD 4544 A/T cooler, RCI AL Skids, OPOR sliders, Morimoto Mini D2S Stage III retrofit, Morimoto XB LED Fogs.
(SOLD) 1999 4runner Limited A/T 4X4 w/ factory e-locker. OME 811 /906, Bilstein 5100, TRS Morimoto mini stage III HID retrofit, B&M 70268 SuperCooler Transmission Cooler
danz is offline   Reply With QuoteReply With Quote
Old 01-11-2014, 06:41 PM #2
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
The sending unit for the temp gauge on the dash is at the back of the engine by the firewall. I'm guessing those broken wires have something to do with it.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 01-11-2014, 07:44 PM #3
I was afraid you were to say that. Now I need to figure out where the wire runs to.
Old 01-11-2014, 07:48 PM #4
kball's Avatar
kball's Avatar
Is that green part in your pic a terminal? Looks like the wire goes in there.
236K miles
Old 01-11-2014, 08:55 PM #5
The green thing looks like a butt splice to the same connector as the broken wire but I could be wrong. I'll have to get some stuff out of the way to try to get a clearer look.
Need help with temp gauge and broken wire-p1030259-jpg
Old 06-01-2023, 12:55 PM #6
Auce Auce is offline
Auce is on a distinguished road
Bumping an old thread here as I have the same exact problem. I texted Brillo a ton and he was very helpful in locating the sensor, after a closer look my wire is also snipped off. I'm going to add 2 attachments, screenshots of suggestions as to what to do, with all that being said, I'm not savvy at all on what the FB screenshot suggests. I don't know jack about electrical. If this sounds like a hassle, would I be better off just getting a scan gauge?
I didn't provide pics of my own as I can barely get back there but I found the snipped wire for sure. With the warm summer aproaching, I'd like to have some sort of temperature gauge working properly so I don't risk overheating and having no warning. Thanks in advance.
IMG-5982 hosted at ImgBB — ImgBB
IMG-5983 hosted at ImgBB — ImgBB
Auce is offline   Reply With QuoteReply With Quote
Old 06-01-2023, 01:05 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I might have that connection on my junk engine harness. I have to look
Old 06-01-2023, 01:41 PM #8
Thank you Jon.
98 4runner 4 cyl. gas gauge and temp gauge top hat 3rd gen T4Rs 2 07-05-2017 03:56 PM
2001 SR5 2WD - Bubbles in Tach gauge and Temp gauge tenro1 3rd gen T4Rs 7 01-01-2014 07:07 PM
Tach, Fuel Gauge, Temp Gauge, Oil Pressure Gauge, Alternator Quit Working silentrunner Classic T4Rs 3 10-05-2013 12:51 PM
Temp gauge hikenbike 4th Gen T4Rs 5 07-14-2013 02:39 PM
I wish my outside temp gauge was broken seabun Gallery 0 08-01-2012 06:48 PM
