Old 01-12-2014, 10:13 AM #1
Swimmerboy2112's Avatar
Swimmerboy2112 Swimmerboy2112 is offline
Swimmerboy2112 is on a distinguished road
Direct replacement switches
Hello all,
Like the title says I am looking for direct replacement switches for my 98' 4Runner. I'd like to add foglights (and other stuff later on), and was wondering if anyone makes direct drop in place switches.
I found these from Slee Offroad and they appear as though they'd fit, just seeing what anyone else can suggest.
Scroll down to Auxiliary Light Switches
Slee - Electrical Switches
Swimmerboy2112 is offline   Reply With QuoteReply With Quote
Old 01-12-2014, 11:50 AM #2
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
These switches are one place Toyota standardized for quite a while. And yes some of what Slee offers will work for you. You can of course, do enough research to find part numbers for what you want and buy them from Toyota. If you have the time, you can visit some wrecking yards and probably find some there too!
Of course the later Toyotas use a smaller footprint, I'm sure you saw that.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 01-12-2014, 03:03 PM #3
Good to know. Looks like I'll be doing a little hunting in the local junkyards.
I don't suppose you know any places that make direct fit switches with different labels like "winch" and other stuff on them?
Old 01-12-2014, 03:34 PM #4
Not direct fit, no. But if you want custom, you can try these.
OTRATTW
Old 01-12-2014, 04:55 PM #5
OTRATTW
Yea I've seen that sure before. I'm really trying to keep the stock appearance of the truck, looks cleaner IMO. Thanks for the link though!
Old 01-13-2014, 07:31 PM #6
MGP's Avatar
MGP MGP is offline
MGP is an unknown quantity at this point
MGP MGP is offline
MGP's Avatar
These will drop right into 96-02 panel knockouts too:
GSW-45 Rocker Switch - Scion OEM Style
I used them when I added a switch for my power antenna, looks factory and works great.
MGP is offline   Reply With QuoteReply With Quote
Old 01-13-2014, 07:37 PM #7
I appreciate the link, but that's not exactly what i'm looking for.
Thanks though.
Old 01-14-2014, 03:02 AM #8
JD914's Avatar
JD914 JD914 is offline
JD914 is on a distinguished road
JD914's Avatar
Here you go...
http://www.aironboard.com/online/roc...placement.html
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
JD914 is offline   Reply With QuoteReply With Quote
Old 01-14-2014, 07:04 AM #9
Originally Posted by JD914 View Post
Yes! Perfect thank you!
Old 01-14-2014, 08:03 AM #10
TNRunner99's Avatar
TNRunner99 TNRunner99 is offline
TNRunner99 is on a distinguished road
TNRunner99's Avatar
Attachment 107742
This is what I used for my fogs on my '99. Just Google "Toyota fog light switch" and plenty of pics will come up. I think its factory Toyota. It fits perfectly in the switch blanks and blends in well with the other dash switches.
1999 4Runner SR5 4x4 Desert Dune
Lift- 3" Toytec/Bilstein-front, LC Coils/LC Tokico Blacks-rear
285 Maxxis Bighorns on 16" ATX Mojaves
ARB-front, CBI plate w swingout-rear
1997 LX450 Black OME 2.5" 315 ST Maxx 2016 4Runner 4x4
TNRunner99 is offline   Reply With QuoteReply With Quote
Old 01-14-2014, 10:13 AM #11
Originally Posted by TNRunner99 View Post
Attachment 107742
I saw one like that it was on a set of dealer installed fog lights on a 97 4Runner. That's not a bad switch but I'd prefer the kind you push in and out not the toggle type. I know I'm picky.
Old 01-15-2014, 03:13 AM #12
TNRunner99's Avatar
TNRunner99's Avatar
Got ya. Yeah the only issue I've had with this one is I can't seem to get it wired to backlight the switch. Tried several different slots in the fuse box but none have worked so far.
Old 01-15-2014, 03:40 AM #13
JD914's Avatar
JD914's Avatar
You don't need to go to the fuse box for back lighting. Simply tap into the same wire on an existing switch, and they'll light up together.
04 V8 Limited
Old 04-05-2020, 12:04 PM #14
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
Reviving this thread. Are there any updated OEM style switches? Preferably push button, but if not, I’d consider rocker style too for turning on my lightbar.
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
benjamin247 is offline   Reply With QuoteReply With Quote
direct drop in switches? KBToys 4th Gen T4Rs 48 11-21-2015 03:11 PM
Brand New Bosal 099-236 Direct Catalytic Converter Replacement terrytcl For Sale: T4R Items 2 01-17-2013 09:30 AM
Direct replacement LED interior group buy #2! so_LED 3rd gen T4Rs 94 01-02-2012 02:25 PM
FS: Custom Y-pipe exhaust V8 direct replacement RXvedub Classifieds - buy & sell (no commercial ads please) 4 03-18-2011 12:38 AM
Any direct bolt-on replacement calipers for 4th gen? Jed 4th Gen T4Rs 4 05-25-2010 09:09 PM
