Old 01-23-2014, 11:22 AM #1
Kirk_B Kirk_B is offline
Kirk_B is on a distinguished road
Driveshaft bolts at transfer case flange pressed on?
I was removing my driveshafts to pull the transmission and noticed that the driveshaft bolts at both differentials came out without issue, while a few of the bolts on the transfer case flange stayed in.
I was wondering if these bolts at the transfer case flange are supposed to be pressed on? A couple are still in the flange, but a few came out. Can I just loctite these ones back in, or do I have to remove the flange and have them pressed in?
Kirk_B is offline   Reply With QuoteReply With Quote
Old 01-23-2014, 11:56 AM #2
eatmorechickenx eatmorechickenx is offline
eatmorechickenx is on a distinguished road
If you mean the fit on the bolt in the hole they should be snug with no play but not necessarily pressed. If you mean the nut on the bolt, yes it should be tight and some BLUE locktite wouldn't hurt.
eatmorechickenx is offline   Reply With QuoteReply With Quote
Old 01-23-2014, 12:04 PM #3
white_n_slow's Avatar
white_n_slow white_n_slow is offline
white_n_slow is on a distinguished road
No need to press anything, just snug 'em down (not sure the torque spec off the top of my head) and check again in a few hundred miles.
If you need to get the stuck ones off, I assume a few taps of the BFH would do the trick.
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
white_n_slow is offline   Reply With QuoteReply With Quote
Transfer case output flange studs UnderFire 3rd gen T4Rs 11 11-21-2013 07:46 PM
play in transfer case flange 93cr250 3rd gen T4Rs 1 09-03-2013 02:54 AM
Leak from transfer case to driveshaft. Zuke 4th Gen T4Rs 7 05-23-2011 02:44 PM
Tips on removing driveshaft yoke/flange bolts? Philbert Classic T4Rs 16 10-24-2008 12:25 AM
