Old 01-25-2014, 12:07 AM #1
PuroPinchePedo PuroPinchePedo is offline
PuroPinchePedo is on a distinguished road
Wider wheel vs using spacers
So I have a 97 4runner limited. It has the huge factory flares. It's 2wd and I want to lift it. I also want to use a wider wheel so it fills up the flares. I see a lot of people use spacers. Is there any difference with using a 10inch wide wheel as oppose to going 7or8 inch and adding a 1.25 spacer? I would prefer not to use the spacer but don't know if anyone has had a problem with either set up. Thanks!
PuroPinchePedo is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 12:21 AM #2
Skidmarcx's Avatar
Skidmarcx Skidmarcx is offline
Skidmarcx will become famous soon enough
Skidmarcx's Avatar
It's better to not use them because it puts more stress on your lug nuts, but it's an option if you can't afford new wheels.
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
Skidmarcx is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 12:59 AM #3
cdrewferd cdrewferd is offline
Banned
cdrewferd is on a distinguished road
Banned
Wider wheels isn't necessarily what you need. You need wheels with less backspacing. Most stock Toyota wheels have around 4.65" backspacing. Get a wheel that has 4" or 3.5".
cdrewferd is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 10:31 AM #4
Brilliant's Avatar
Brilliant Brilliant is offline
Brilliant is on a distinguished road
Brilliant's Avatar
Lug stress concern is largely nonsese for hubcentric spacers.
Its more about the chance to use them incorrectly and more to go wrong.
Brilliant is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 11:01 AM #5
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Exactly!
The stresses on the lugs increase regardless of whether you use spacers, or a more negative offset wheel. The hubcentric wheel and spacer reduce this enough it is not a real concern. Provided you install correctly and don't get stupid wide. Spacers can be a pain, but certainly more economical than replacing the wheels.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 11:15 AM #6
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Bingo. THis is correct, don't go wider, go with different backspacing
Originally Posted by IBallEngineer View Post
Exactly!
They are not quite the same loading though. Less backspaced wheels will put less stress on the lugs than using hub-centric spacers, but both of these will put less on them than lug centric spacers.
With the hub centric spacers, you are turning some of the shear stress into a moment (bending stress). While less-backspaced wheel increase the overall moment on the hub, that stress is imparted to the lugs very close to the hub, whereas with spacers the lug nut is closer to the end of the lug, so the bending stress on the lugs can increase a bit.
For less back-spaced wheels, the wheel itself takes a bit more of the stress that will be taken by the spacer and lugs in you go that route.
That said, guys that have properly installed good hub-centric spacers have wheeled them with relatively little problems, so I'd say follow the money, whichever is cheaper.
Just be sure to get legitimate hub centric spacers, not ebay specials. Trash aluminum and poor tolerances can significantly increase the stress the spacers will put on your lugs.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 11:53 AM #7
Ok... I will absolutely make sure of the backspacing. I would prefer to avoid the spacers cuz I feel like the less I have to add the better. Great info, much appreciated!
Old 01-25-2014, 11:59 AM #8
So help me understand backspacing. So the lower the number the more the rim would stick out the side of the vehicle? So the wheels in the pic I attached would work well then?
Wider wheel vs using spacers-wheels-jpg
Old 01-25-2014, 01:33 PM #9
thebrandon's Avatar
thebrandon thebrandon is offline
thebrandon is on a distinguished road
thebrandon's Avatar
aside from the lug pattern yes, they would work.
thebrandon is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 02:26 PM #10
SweetWaterSurprise SweetWaterSurprise is offline
Banned
SweetWaterSurprise is on a distinguished road
Banned
Good info here
SweetWaterSurprise is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 02:27 PM #11
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Just don't be like me ...
285x75x16 w/ 1.5" spacers, factory Toyota 5-Star 16" Wheel.
Damage report:
1. Bottomed out the front end when I hit some dirt mogals on my way out of DV. This resulted in a bent passenger fender because my 285s were sticking out toooo far. The front drivers and passenger flares completely popped off.
Bent Passenger Fender
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 03:29 PM #12
Damage report:
Funny you point that out. My truck had the lower ball joint go out and the front pass wheel fell into the fender causing the same problem. Let me ask you a question. I feel it would probably be better to find another fender at a salvage yard with the same paint job than fixing that one. Have you fixed yours yet and if so, what did you do or planning on doing?
Old 01-25-2014, 03:59 PM #13
BrianSD_42's Avatar
BrianSD_42's Avatar
It was bent back for about $100-$150.
Basically the shop charged me $240 to rebend the panel back (they did a good job) and to repaint both front limited flare pieces.
It's already bent back and I am going to mount the flares today.
If you want to read more see my thread and say hi.
Link ----> http://www.toyota-4runner.org/3rd-ge...ce-thread.html
Old 01-25-2014, 09:12 PM #14
Brilliant's Avatar
Brilliant's Avatar
Exactly!
Assuming the distance tire rides inside/outside the fender is fixed. Worst case lug centric, its a beam in bending. Sheer is constant, moment at the hub lugs is the same for both cases (spacer or offset wheel). Moment on the wheel/spacer interface is less than the hub.
Hub centric spacers, hub centric wheels with the same gap, the hub gets loaded the same. The spacer sees less bending than the hub, same shear. Spacers or offset, where the tire rides relative to the hub creates load the hub lugs see.
Been some time though, my 1st year could be off.
Used wheel 1.5" wheel spacers. X4 Rc4r For Sale: Suspension/Wheels/Tires 1 04-22-2012 06:02 PM
WTT SoCal: My 1.5" Wheel Spacers for Your 1.25" Wheel Spacers ryhi Want to Buy/Trade 3 03-20-2012 02:45 AM
wheel spacers? Brayt4r10 5th gen T4Rs 6 12-01-2011 11:54 AM
3rd gen Toytec Spacers and Spidertrax wheel spacers (all years) Hawkdog21 Classifieds - buy & sell (no commercial ads please) 0 10-25-2010 03:30 PM
Wheel Spacers vs. Wheel Offset R8RRunner 4th Gen T4Rs 2 01-23-2009 09:47 AM
