Old 09-01-2019, 02:24 PM #181
Silver Supra's Avatar
Silver Supra Silver Supra is offline
Silver Supra will become famous soon enough Silver Supra will become famous soon enough
Originally Posted by ChildrenOfBodom View Post
Hey Jim,
Ignore the fact that your new transmission comes from a 1999 truck, it's not going to matter in this case.
What you need to focus on is your own vehicle's requirements - swap an ECU from a 98 M/T, it will plug right into your 98 Auto harness.
James
Thanks James. I’ve heard that it will plug right in with no re-pinning and I’ve also been told it will smoke the ECU if I just plug it in... so your reply is great to hear!
I still plan to get the wiring schematics to be sure before I make an expensive mistake. 😭
Silver Supra is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 02:47 PM #182
SJM8801 SJM8801 is offline
SJM8801 is on a distinguished road
Originally Posted by danthemanx07 View Post
I will be interested to hear how the ECU works out. Keep us posted on that one. I have a 1998 manual ECU that I have yet to swap in.... CEL has not bothered me much after three years.
No work needed for brake pedal. There should be two switches on the clutch pedal. One at the top and one at the bottom. The one at the top will disengage the cruise control and the one at the bottom is the neutral safety switch. I think this is it, but this is all from memory of work done three years ago now...
Do you mean 2 pigtails coming off the auto transmission? I know I had unused wires that ran to the auto tranny after the swap. I am pretty sure I only hooked up the reverse lights to the transmission.
Let me know how you wire the clutch cancel switch. I finally picked one up, but I have not wired it in yet.
FOR your 5 speed swap you just kept the auto Ecu in? Does it run fine? I’m about to do a 5 speed swap and don’t feel like paying $500 for a manual eco.
SJM8801 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 03:11 PM #183
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
It'll run fine with the auto ecu, you'll just get check engine light telling you your shift solenoids are malfunctioning (cause they aren't there).
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 07:18 PM #184
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
On the topic of wiring, does anyone know how to wire up stuff like the clutch start cancel circuit? My 2000 tacoma parts truck that I got my trans from has it, but I have no idea how it would integrate into my 2000 auto wiring harness and 2000 m/t ecu I have.
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 09:27 PM #185
Ok sweet. I’ve heard that you need a manual ecu because the ignition timing and fuel mapping is different, but I wouldn’t see why it would be different
Old 08-04-2020, 09:31 PM #186
danthemanx07 danthemanx07 is offline
danthemanx07 is on a distinguished road
Negative hombre. You will be fine. Ran mine with the Auto ecu for more a few years before I got off my but and re=pinned the harness. CEL will be on but that is it.
2005 GX470
3.4l A340 Automatic to R150F Manual Transmission Swap
http://ttora.com/forum/showthread.php?t=159482
danthemanx07 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 09:33 PM #187
You need to get the wiring manual for the 2000. The wiring and switch changed at least once with the third gens, and I am not sure it is the same for the Tacomas. I do not remember it being that hard though. I dont think you have to integrate it into the harness really. It should only serve to close the circuit that would other with be closed by the switch at the bottom of the clutch travel.
2005 GX470
Old 08-04-2020, 10:31 PM #188
Awesome thanks dude!!!
Old 08-05-2020, 05:39 PM #189
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Dropbox with 2000 EWD: Dropbox - 2000 4Runner Electrical Wiring Diagram (EWD383U) - Printable - Simplify your life
Old 08-07-2020, 06:37 PM #190
G’s_4runnah G’s_4runnah is offline
Real Name: Nick G
G’s_4runnah is on a distinguished road
Real Name: Nick G
Hey just a quick question, as anyone attempted this on a 2001? When everyone says you need the ecu, are they referring to an ecu that matches the year of the manual transmission or an ecu from the year of the vehicle that it’s going into? I’m curious if the swap is possible in the 2001 due to it never being offered in a manual configuration.
G’s_4runnah is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 05:23 PM #191
negative hombre. You will be fine. Ran mine with the auto ecu for more a few years before i got off my but and re=pinned the harness. Cel will be on but that is it.
also will my transfer case from my auto bolt right up to the manual transmission? Or do i need an adapter plate?? Need to know asap
Old 09-22-2020, 06:02 PM #192
Will bolt up.
2005 GX470
Old 09-22-2020, 07:27 PM #193
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
You need a 2003 or 2004 Tacoma ECU. @anniesball72 and @Tyler James Inc have done it. Look at @Tyler James Inc 's thead: Tyler James Inc's Ultimate '01 SR5 starting at page 3.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 07:58 PM #194
Will bolt up.
Awesome thanks man for the quick reply!!
Old 09-23-2020, 12:30 AM #195
Real Name: Nick G
Real Name: Nick G
@Team_Jake thank you! The swap is underway!
5 speed auto JamesDean91 3rd gen T4Rs 19 04-30-2021 02:28 PM
Possible 5 speed swap input appreciated zgensler31 3rd gen T4Rs 114 12-02-2016 01:23 AM
Reverse gear/speed sensor input jsukey Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-01-2012 11:38 AM
Full Synthetic Swap At 102,000. Thoughts and Input 03L4RUNNER Maintenance/Detailing 2 10-18-2010 08:43 PM
RPM differences between 4 speed Auto and 5 speed standard? kenlam 3rd gen T4Rs 2 10-14-2005 09:32 AM
