Old 01-29-2014, 07:50 PM #16
Swimmerboy2112's Avatar
Swimmerboy2112 Swimmerboy2112 is offline
Swimmerboy2112 is on a distinguished road
Hmm I might try plugging in the donor ECU anyway, worse comes to worse I will just fry that ECU and have to buy a correct one anyway.
I'll check out your thread for the wiring.
Swimmerboy2112 is offline   Reply With QuoteReply With Quote
Old 02-11-2014, 05:24 PM #17
Success!!
Old 02-11-2014, 05:38 PM #18
Brique's Avatar
Brique Brique is offline
Brique is on a distinguished road
Brique's Avatar
I have a question for you guys: I've seen threads like this and in my daydreams I've thought that if my auto trans ever dies, it might be cool to switch to a manual. I have a 2001 with vsc/trac and the multi mode transfer case. If i did the swap, would i be able to keep the multi mode and the vsc/trac?
Brique is offline   Reply With QuoteReply With Quote
Old 02-11-2014, 07:45 PM #19
zgensler31 zgensler31 is offline
zgensler31 is on a distinguished road
In theory you can, it just gets more complicated wiring wise.
1996 Limited 4X4
Desert Dune, 140,000 miles, E-Locker
About to get a 5-Speed r150f!
zgensler31 is offline   Reply With QuoteReply With Quote
Old 02-11-2014, 08:42 PM #20
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Thumbs down
Even if you manage to get the 5 speed bolted up and get the transfer case working, your year limits to only automatic transmission compatible ECUs. You'll throw a CEL for the missing automatic transmission components. There will be a lot of now defunct wires left over from the auto transmission harness.
Manual swap in 01-02 would not be a fun thing to do IMO... 99-00 have manual transmissions available, making an ECU swap of the same year a solution to auto ECU CEL's. I don't think theres a way to make the auto ECU not throw codes. That could be annoying to look at daily, moreso when inspection or smog come around
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 02-11-2014, 09:32 PM #21
Agreed. Not worth it IMO.
Old 02-11-2014, 10:18 PM #22
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
While you are correct with the defunct wires that will need to be stores somewhere out if the way, there is a way to keep that CEL from being on.
It takes some studying, some creative thinking, and time, but if you can figure out which wires need to be connected to make the ECU think the transmission is in NEUTRAL, you'll be fine.
You won't get any CELs, and you'd be able to pass inspection, if you needed to.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 02-11-2014, 11:03 PM #23
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Damn I was looking on craiglist and came along to this same vehicle haha. Looks like you grabed it already
kolelt is offline   Reply With QuoteReply With Quote
Old 02-12-2014, 10:04 AM #24
Yeah I got it about 3 weeks ago now. As you know, these are hard to come by in our area.
Old 02-12-2014, 01:20 PM #25
Moderator
Real Name: James
Moderator
Real Name: James
I disagree.
Wiring the neutral safety switch isn't going to fix it. A 3.4 auto ECU will definitely throw codes, there are missing solenoids and sensors. Those will be missing whether or not you're in neutral.
Here are some codes I found online of typical 5 speed swaps on the 3.4 using the automatic ECU:
P0710- Transmission Fluid Temperature Sensor Circuit Malfunction
P0753- Shift Solenoid B Circuit Electrical
P0758- Shift Solenoid B Circuit Electrical
P0773- Shift Solenoid E Circuit Electrical
Is there a way to manipulate the ECU into thinking the missing parts are there and in functioning order? If even a malfunction can throw a code, the readings must be very specific.. I don't see how it could be done without ridiculous amounts of extra effort, or a simulator of some sort. I'd start looking at 2002 Tacoma 3.4 5speed ECUs and try to get one of those to work, there's pinouts online and in the FSM, it could be compared and repinned if need be. I am unaware of differences maybe involved with throttle by wire or other Tacoma/4Runner differences, but that's a good place to start looking.
A great quote on TTORA from mosk
I think Toyota optimized the factory fuel and timing maps differently for the auto vs. the manual transmission vehicles, to meet CAFE requirements (fleet economy) and for emissions. That (and CA emissions) are the main reasons I want to do the ECU swap instead of keeping the auto ECU and tricking the computer. I've had enough of tricking computers . If I'm going to spend the money to convert this truck to a manual, I want to drive it with the right fuel maps, the right timing maps, and no CELs. Been there, done that.
-Jeff
Old 02-12-2014, 02:11 PM #26
Doc2012's Avatar
Doc2012's Avatar
I disagree.
WADR,
I didn't say the neutral safety switch.
Make the ECU think the transmission is in neutral.
This is from a '91, but same principle:
http://m.yotatech.com/showthread.php...482&styleid=51
Old 02-12-2014, 09:51 PM #27
Re-railing this thread for a moment.
Here's a list of what I have pulled for the swap, please let me know if I am forgetting something.
-Manual trans
-T-Case
-Shifters
-Shifter trim
-ECU
-Driveshafts
-Clutch pedal assy and all connectors
-Brake pedal assy and all connectors
-Clutch cancel switch
-Clutch (will be replaced)
-Flywheel (will be replaced)
-Master cylinder
-Slave cylinder
-Clutch lines
-Crossmember
I think that's it, right?
I'm still super confused on wiring. That's basically all that's holding me up right now.
Old 02-12-2014, 10:09 PM #28
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
I disagree.
I think the easiest way to fix this is to Take an ohm reading of each solenoid and buy the equilivant ohm resister and wire it in.
The ECM will see the load on the circuit and think all is fine.
Do the same for the Temp sender. Find a ohm value for the correct temp and wire the corresponding resister in place.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 02-12-2014, 10:12 PM #29
According to the Toyota Parts Cross-Reference, the part number 89661-3D140 (which is the number on my ECU) fits 1996-2002 4Runners. I think i'm gonna try it in my 97'
Old 02-12-2014, 10:18 PM #30
Singtoe's Avatar
Singtoe's Avatar
So not true.. 2001 and 2002 4runners are drive by wire and that by itself would need a totally different ecu.
5 speed auto JamesDean91 3rd gen T4Rs 19 04-30-2021 02:28 PM
Possible 5 speed swap input appreciated zgensler31 3rd gen T4Rs 114 12-02-2016 01:23 AM
Reverse gear/speed sensor input jsukey Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-01-2012 11:38 AM
Full Synthetic Swap At 102,000. Thoughts and Input 03L4RUNNER Maintenance/Detailing 2 10-18-2010 08:43 PM
RPM differences between 4 speed Auto and 5 speed standard? kenlam 3rd gen T4Rs 2 10-14-2005 09:32 AM
