Old 02-12-2014, 10:21 PM #31
Swimmerboy2112's Avatar
Swimmerboy2112 Swimmerboy2112 is offline
Swimmerboy2112 is on a distinguished road
Originally Posted by Singtoe View Post
So not true.. 2001 and 2002 4runners are drive by wire and that by itself would need a totally different ecu.
So I thought, looks like my cross-reference is not reliable, bummer.
Swimmerboy2112 is offline   Reply With QuoteReply With Quote
Old 02-12-2014, 10:26 PM #32
coinball's Avatar
coinball coinball is offline
coinball is on a distinguished road
coinball's Avatar
I think the easiest way to fix this is to Take an ohm reading of each solenoid and buy the equilivant ohm resister and wire it in.
The ECM will see the load on the circuit and think all is fine.
Do the same for the Temp sender. Find a ohm value for the correct temp and wire the corresponding resister in place.
This is what I would do. Also, I think the FSM has the resistance values published for the sensors/solenoids as part of the testing documentation.
Eric
'02 Limited
1st Gen TRD SC - 2.2" Pulley - URD 7th Injector - TRD Headers - URD 02 Sim - Hilux Surf Field Monitor Unit - Hilux Surf Power-Folding Mirrors - Hilux Surf Rear Spoiler - Tundra Brakes - TRD Tranny Cooler - OME906 - '99 Front Coils
coinball is offline   Reply With QuoteReply With Quote
Old 02-12-2014, 11:10 PM #33
zgensler31 zgensler31 is offline
zgensler31 is on a distinguished road
Originally Posted by Swimmerboy2112 View Post
Re-railing this thread for a moment.
Here's a list of what I have pulled for the swap, please let me know if I am forgetting something.
-Manual trans
-T-Case
-Shifters
-Shifter trim
-ECU
-Driveshafts
-Clutch pedal assy and all connectors
-Brake pedal assy and all connectors
-Clutch cancel switch
-Clutch (will be replaced)
-Flywheel (will be replaced)
-Master cylinder
-Slave cylinder
-Clutch lines
-Crossmember
I think that's it, right?
I'm still super confused on wiring. That's basically all that's holding me up right now.
Looks good to me, only thing I would mention is the drive shafts. Some have made the auto ones work, but you have the manual ones, you might as well use those, that's wgat I plan on doing.
1996 Limited 4X4
Desert Dune, 140,000 miles, E-Locker
About to get a 5-Speed r150f!
zgensler31 is offline   Reply With QuoteReply With Quote
Old 02-12-2014, 11:20 PM #34
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Ok. So here's a question....
Your runner is a 97, right? The donor is a 96, right?
Why not just pull the ECU and The harness and put them in your truck?
Speaking from experience, it's not hard to do at all. Pull the intake off, and disconnect everything. Takes about 45 minutes to do.
As long as it's a 3.4, everything should plug together, except for MAYBE the injectors. But just swap them out and you should be fine.
Just my .01.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 02-13-2014, 12:16 AM #35
Jon's Avatar
Jon Jon is offline
Jon is on a distinguished road
Jon Jon is offline
Jon's Avatar
ALL info needed for a 97 4Runner 5 speed swap. Wire details included and no ECU swap.
5spd swap, HERE GOES NUTHIN!
Keep the 5 speed t-case and use the 5 speed shafts and cross member. Easiest way.
I am still running an F1 Racing clutch but had to upgrade to stage 3 due to the super charger and the rock climbing abuse. Now it bites hard as hell!
Marlin Crawler Taco Box 4.7 is in the near future.
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
Jon is offline   Reply With QuoteReply With Quote
Old 02-13-2014, 08:59 AM #36
Originally Posted by zgensler31 View Post
Looks good to me, only thing I would mention is the drive shafts. Some have made the auto ones work, but you have the manual ones, you might as well use those, that's what I plan on doing.
Oh yeah I have them pulled I just forgot to put them on my list.
Just my .01.
That's an idea but it seems like a lot more work than necessary. I'd rather just swap in the ECU.
Interesting. I read your thread. I see you stuck with the auto ECU. I am pretty attainment on using the M/T ECU.
Old 02-13-2014, 11:46 AM #37
Im planning on swapping the harnesses. Especially because there us a good chance you could fry the ecu.
Since the ecu is the rarest and one of.the more expensive parts, i wouldnt risk it. But its up to you.
1996 Limited 4X4
Old 02-13-2014, 11:51 AM #38
Hmm... Does the harness run behind the dash? If so, that seems like A LOT of work.
Old 02-13-2014, 01:59 PM #39
Doc2012's Avatar
Doc2012's Avatar
No. No it does not.
take the glove box out. You can see the ECU up in there.
the firewall on the passenger side, there's a little rubber boot.
the ECU harness exits the firewall, runs to the engine and trans. It has connnectors for the BODY harness, but the majority of it goes out the firewall.
hence why I said to change out the harness as well.
Disconnect everything from the ENGINE and TRANSMISSION, that's really it, and then swap in the manual harness.
Old 02-13-2014, 02:01 PM #40
No. No it does not.
Oh good.
Yeah I already have the ECU out. Maybe I will swap the harnesses that seems like the best bet.
Edit: The more I think about it, wouldn't it just be easier to find a 1997 manual trans V6 ecu?
Old 02-13-2014, 03:36 PM #41
danthemanx07 danthemanx07 is offline
danthemanx07 is on a distinguished road
Originally Posted by ChildrenOfBodom View Post
Even if you manage to get the 5 speed bolted up and get the transfer case working, your year limits to only automatic transmission compatible ECUs. You'll throw a CEL for the missing automatic transmission components. There will be a lot of now defunct wires left over from the auto transmission harness.
Manual swap in 01-02 would not be a fun thing to do IMO... 99-00 have manual transmissions available, making an ECU swap of the same year a solution to auto ECU CEL's. I don't think theres a way to make the auto ECU not throw codes. That could be annoying to look at daily, moreso when inspection or smog come around
This is true. Without a manual ECU available, you are going to have to fool your ECU into thinking the transmission is still there. You can do this using a method mentioned below by Singtoe.
I disagree.
Wiring the neutral safety switch isn't going to fix it. A 3.4 auto ECU will definitely throw codes, there are missing solenoids and sensors. Those will be missing whether or not you're in neutral.
Here are some codes I found online of typical 5 speed swaps on the 3.4 using the automatic ECU:
P0710- Transmission Fluid Temperature Sensor Circuit Malfunction
P0753- Shift Solenoid B Circuit Electrical
P0758- Shift Solenoid B Circuit Electrical
P0773- Shift Solenoid E Circuit Electrical
Is there a way to manipulate the ECU into thinking the missing parts are there and in functioning order? If even a malfunction can throw a code, the readings must be very specific.. I don't see how it could be done without ridiculous amounts of extra effort, or a simulator of some sort. I'd start looking at 2002 Tacoma 3.4 5speed ECUs and try to get one of those to work, there's pinouts online and in the FSM, it could be compared and repinned if need be. I am unaware of differences maybe involved with throttle by wire or other Tacoma/4Runner differences, but that's a good place to start looking.
A great quote on TTORA from mosk
Tacoma ECUs are different I believe. I know they were in 1998, the year of my 4runner, so you can't just pull a Tacoma one without running the same risk that the OP would run by popping in the ECU he already has from the 1996 donor vehicle.
WADR,
I didn't say the neutral safety switch.
Make the ECU think the transmission is in neutral.
This is from a '91, but same principle:
Automatic ECU into Manual - YotaTech Forums
This may be true, but it assumes that there are no additional sensors in the later model years that the ECU looks for. If anyone is going to get creative, they should get creative and build some shift solenoid simulators as Singtoe suggest. This should work fine.
I think this would be the best way to do it without an ECU. A fella over on TTORA I think started this project before we found a way to swap in manual ECUs without frying them. Unfortunatley, that information is not freely available for 4runners. The guys on TTORA compiled the data about ECUs for the Tacomas. I just got lucky that the guy doing the work had a 1998 4runner and the data for it.
Oh good.
You run the same risk that I mentioned before. There is no way of knowing that the manual and auto ECUs have the same pinouts. You could get the info by buying a one day subscription to the toyota information system. If you go to that thread on TTORA that I mentioned in an earlier post, you can get an idea about the differences between the manual and auto ECUs. Truthfully I have never compared any ones other than the ones for a 1998 4runner, but I know that in 1998 the ECUs were different.
2005 GX470
3.4l A340 Automatic to R150F Manual Transmission Swap
http://ttora.com/forum/showthread.php?t=159482
danthemanx07 is offline   Reply With QuoteReply With Quote
Old 02-13-2014, 03:38 PM #42
-Manual trans
-T-Case
-Shifters
-Shifter trim
-ECU
-Driveshafts
-Master cylinder
-Slave cylinder
-Clutch lines
-Crossmember
Leaving the ECU issue aside, the rest of the wiring is pretty easy and should be documented on my thread on TTORA. The wiring on the transmission harness may be different, but you could check out Bawlz's thread. His is a 1997.
2005 GX470
Old 02-13-2014, 03:42 PM #43
Here is another thread that may be of use. This fella was doing his swap the same time I was, so we exchanged thoughts on a number of things. A340F- to -W59 - TTORA Forum
2005 GX470
Old 02-13-2014, 03:56 PM #44
I don't think i'll need to do any other wiring with the ECU aside from plugging it in.
Hmm interesting, I will check it out.
Basically, as far as i'm concerned, here is a list of the wiring I have to do, correct me if i'm wrong.
-There are 2 switches on the brake pedal assy, I am assuming I already have that wiring in my auto.
-There is a switch on my clutch pedal assy which needs to be wired up
-There are 2 pigtails on my transmission 1 is for the reverse lights and what's the other for?
-There is the clutch cancel switch
Old 02-13-2014, 04:31 PM #45
I will be interested to hear how the ECU works out. Keep us posted on that one. I have a 1998 manual ECU that I have yet to swap in.... CEL has not bothered me much after three years.
No work needed for brake pedal. There should be two switches on the clutch pedal. One at the top and one at the bottom. The one at the top will disengage the cruise control and the one at the bottom is the neutral safety switch. I think this is it, but this is all from memory of work done three years ago now...
Do you mean 2 pigtails coming off the auto transmission? I know I had unused wires that ran to the auto tranny after the swap. I am pretty sure I only hooked up the reverse lights to the transmission.
Let me know how you wire the clutch cancel switch. I finally picked one up, but I have not wired it in yet.
2005 GX470
5 speed auto JamesDean91 3rd gen T4Rs 19 04-30-2021 02:28 PM
Possible 5 speed swap input appreciated zgensler31 3rd gen T4Rs 114 12-02-2016 01:23 AM
Reverse gear/speed sensor input jsukey Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-01-2012 11:38 AM
Full Synthetic Swap At 102,000. Thoughts and Input 03L4RUNNER Maintenance/Detailing 2 10-18-2010 08:43 PM
RPM differences between 4 speed Auto and 5 speed standard? kenlam 3rd gen T4Rs 2 10-14-2005 09:32 AM
