Originally Posted by Swimmerboy2112
Does that look similar to how you ran your wires?
Also I took a look today, there is only 1 plug on the transmission but there are 2 plugs on the t-case.
It looks like i'm just about ready to do this swap, just gotta wait for Marlin to get some clutches in stock.
Here is the summation of the wiring on mine:
black wire->depress switch->black/white wire (this will allow the engine to start when the clutch is pushed in)
black/yellow->release switch-> white/red wire (this will make the computer believe it's in drive when the clutch is extended thus allowing your cruise to function)
black/yellow->reverse switch-> red/yellow wire (this will illuminate the reverse lights when shifted into reverse)
Check out posts 17 and 25 over on my thread on TTORA for some additional info.
Do you guys think using the J-shift t-case out of the donor will require extra wiring over the push button/lever system currently in my truck?
No. The J-shifter doesnt require anything really. The one connector it uses *I think* only serves to illuminate the light on the dash.
2005 GX470
3.4l A340 Automatic to R150F Manual Transmission Swap
http://ttora.com/forum/showthread.php?t=159482
