Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 05-22-2022, 10:00 AM #331
Stephen941 Stephen941 is offline
Stephen941 is on a distinguished road
Green LEDs?
Has anyone tried the Green colored LEDs? I'm thinking of finally tackling this project but maybe not replacing all of the lights. And would prefer not to have different color lights. I think I would like the Amber but have heard that, for example, the light behind the clock is difficult to replace, and that the blinker LEDs are too bright. So just thinking of going with Green in order to keep a consistent look.
Stephen941 is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 01:42 PM #332
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I've seen guys do red and blue for the 3 behind the 2 main dials. I did bright white.
You can't change the clock internally, easily, but you can put a gel film over it, externally
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-28-2022, 12:59 PM #333
CC4Runner CC4Runner is offline
CC4Runner is on a distinguished road
LED Swap
Great article and thanks for sharing the info. I have a 99Limited Runner and used the chart to change out mine. All went well except I am having issues with the turn signals. Chart did not specify signal bulbs. I am trying to use the #74 like you said in the article for your 01. Is #74 used for 99 as well or do I need another type bulb? #74 fit in just fine but signals aren't working.
CC4Runner is offline   Reply With QuoteReply With Quote
Old 11-03-2022, 10:52 AM #334
Jason7191 Jason7191 is offline
Jason7191 is on a distinguished road
Has anyone used superlumination lately? Ordered like 10 days ago, heard nothing.
Jason7191 is offline   Reply With QuoteReply With Quote
Old 11-16-2022, 05:36 PM #335
Originally Posted by WeakSauz View Post
Got them from 74 24 Instrument Panel Gauge Colored Led Bulbs Lights and Lamps) (brace yourself for a horribly designed website lol)
The cluster bulbs are
"Plastic Wedge 3X 5630 Samsung" $5.99 each. 230 degree beam angle eliminates the hot spots (I got white)
The website is awful, so just look for the only ones that are $5.99 and it's those. You'll need 3 for the cluster
Word of caution if using this website. The seller claims “ You should plan 3-7 business days to receive your order in the US, if ordered from the website”. If only. They only shipped my order after I asked what was going on two weeks after placing it. It finally arrived 21 days after ordering. Then it arrived short one bulb. So I tell the seller, they imply they didn’t leave it out and ask for pictures which I provided. I haven’t heard anything since. I should have figured they were as tacky and cheap as their website. Unfortunately I didn’t notice I was short a bulb til I had my dash ripped apart. So now I’m scrambling to find something that likely won’t match to get it put back together.
Old 12-13-2022, 04:01 PM #336
Jdeezy Jdeezy is offline
Jdeezy is on a distinguished road
Passenger Seatbelt Indicator 5mm LED bulb
Can someone please direct me to the website where can I buy the
Passenger Seatbelt Indicator 5mm LED bulb for 2002 Toyota 4Runner
Jdeezy is offline   Reply With QuoteReply With Quote
Old 01-14-2024, 07:30 PM #337
RJM549 RJM549 is offline
RJM549 is on a distinguished road
LED conversion for 2002 SR5 LIST
I just converted everything to LED on my 02'. I bought everything on Amazon and I will post all the links.
I was able to use the #74 LEDs for everything in the combination meter (except for the 4WD lights which I did not change). I have not had a problem with them going out. I would recommend buying some dimmer bulbs for the shift position. It is really bright. I'm contemplating on changing these back to halogen.
The biggest problem I had was swapping out my fog lights. I had to drill the small three bolts out of the bottom of the assembly to even change out the bulbs. The bottom cap is now strategically zip tied and its MINT (Roadkill fans know what I'm talking about). Every time I solved one problem another would arise. Needless to say, due to the elements, my wire connectors were brittle and the wires were toast. I ended up having to cut wires and splice my own connecters. The important thing is, they work!
If you swap blinkers bulbs, you will have to install an LED blinker relay to eliminate the hyper flash.
I hope this helps out. I will have pictures and links below.
Interior lights, Tag Lights and 3rd Brake light:
https://www.amazon.com/dp/B078YL1NVN...roduct_details
Combo Meter, Ignition Light, Gear Shifter (I bought 2 of these):
https://www.amazon.com/dp/B0CBM9Z29C...t_details&th=1
A/C Unit Lights:
https://www.amazon.com/dp/B07LCMH75R...t_details&th=1
Rear Window, Rear Defrost Lights:
https://www.amazon.com/dp/B07LCMBSJT...roduct_details
Side Marker Lights (I liked these, but you only need two bulbs):
https://www.amazon.com/dp/B097Y59BGP...t_details&th=1
Front and Rear Blinker Bulbs:
https://www.amazon.com/dp/B07BXP49Q4...t_details&th=1
LED Blinker Relay:
https://www.amazon.com/dp/B07QPSCPM7...roduct_details
Reverse Lights:
https://www.amazon.com/dp/B07M74ZNSZ...t_details&th=1
Brake Lights:
https://www.amazon.com/dp/B071YZQGTS...t_details&th=1
Head Lights:
https://www.amazon.com/dp/B0CMT2RQ93...t_details&th=1
Fog Lights:
https://www.amazon.com/dp/B0CNVRY2K2...roduct_details
LED Dash lights FAQs-image0-jpg  LED Dash lights FAQs-image1-jpg  LED Dash lights FAQs-image4-jpg  LED Dash lights FAQs-r50kyx7r-jpg  LED Dash lights FAQs-qkye57q6-jpg  LED Dash lights FAQs-image0-1-jpeg
RJM549 is offline   Reply With QuoteReply With Quote
Old 01-28-2024, 12:32 PM #338
alex9000 alex9000 is offline
alex9000 is on a distinguished road
This is awesome, thank you. I want to swap over to LED but i'm worried they'll be too bright. I *really* hate bright lights... I could build in a custom PWM dimmer but that's a bit absurd
alex9000 is offline   Reply With QuoteReply With Quote
Dash Lights Are Out... wantahertzdonut Classic T4Rs 10 03-24-2013 02:07 PM
Tail Lights, Markers, License Plate, Dash Lights all out! aeroneer1 3rd gen T4Rs 3 09-01-2012 06:53 PM
Dash Lights Failed. Running Lights Work. CanadianTRD 3rd gen T4Rs 4 08-14-2012 11:10 PM
Dash Lights and Tail Lights Out chaossd 4th Gen T4Rs 1 01-03-2009 07:20 AM
leds in tail lights, no brake lights, buzzing from dash with blinkers??? jamr1 3rd gen T4Rs 0 09-12-2008 07:10 PM
