I just converted everything to LED on my 02'. I bought everything on Amazon and I will post all the links.
I was able to use the #74 LEDs for everything in the combination meter (except for the 4WD lights which I did not change). I have not had a problem with them going out. I would recommend buying some dimmer bulbs for the shift position. It is really bright. I'm contemplating on changing these back to halogen.
The biggest problem I had was swapping out my fog lights. I had to drill the small three bolts out of the bottom of the assembly to even change out the bulbs. The bottom cap is now strategically zip tied and its MINT (Roadkill fans know what I'm talking about). Every time I solved one problem another would arise. Needless to say, due to the elements, my wire connectors were brittle and the wires were toast. I ended up having to cut wires and splice my own connecters. The important thing is, they work!
If you swap blinkers bulbs, you will have to install an LED blinker relay to eliminate the hyper flash.
I hope this helps out. I will have pictures and links below.
Interior lights, Tag Lights and 3rd Brake light:
https://www.amazon.com/dp/B078YL1NVN...roduct_details
Combo Meter, Ignition Light, Gear Shifter (I bought 2 of these):
https://www.amazon.com/dp/B0CBM9Z29C...t_details&th=1
A/C Unit Lights:
https://www.amazon.com/dp/B07LCMH75R...t_details&th=1
Rear Window, Rear Defrost Lights:
https://www.amazon.com/dp/B07LCMBSJT...roduct_details
Side Marker Lights (I liked these, but you only need two bulbs):
https://www.amazon.com/dp/B097Y59BGP...t_details&th=1
Front and Rear Blinker Bulbs:
https://www.amazon.com/dp/B07BXP49Q4...t_details&th=1
LED Blinker Relay:
https://www.amazon.com/dp/B07QPSCPM7...roduct_details
Reverse Lights:
https://www.amazon.com/dp/B07M74ZNSZ...t_details&th=1
Brake Lights:
https://www.amazon.com/dp/B071YZQGTS...t_details&th=1
Head Lights:
https://www.amazon.com/dp/B0CMT2RQ93...t_details&th=1
Fog Lights:
https://www.amazon.com/dp/B0CNVRY2K2...roduct_details
