03-24-2014, 04:04 PM
#16
Originally Posted by TheDurk
Thanks for posting that! It's the same one I ordered last week after mine met the cruel demise at the hands of a car wash. (I'm not used to having to put my antenna down...Tacoma owner)
03-24-2014, 05:14 PM
#17
Replace it! I have a $2.00 ebay carbon fiber shorty and a $12.00 metra antenna kit. I like the low profile look, unlike my cb antenna lol
03-24-2014, 06:03 PM
#18
Is that Antenna in your second pic the same one as the first pic?
03-24-2014, 09:17 PM
#19
Yes it is, it is the one on the Passenger side though The one on the drivers side is my CB antenna.
03-25-2014, 12:58 AM
#20
Link please
Joel
'88 Toyota 4Runner 22re manual
03-25-2014, 02:51 PM
#21
power antenna repair or replace with fixed
Just ordered it from the link posted above.
Thanks TheDurk!
I read all the posts on it I could find, always do, but could not settle on which place to order from till your post. Again, huge thanks, saves much going with a know seller with a known fit.
I belong to all kinds of forums, this group rocks!
97 4Runner Limited 183+K
97 4Runner SR5 308+K Never A Breakdown
Best Vehicles I Ever Owned
Jim Thorpe, Poconos PA.
03-25-2014, 04:10 PM
#22
Real Name: Mr. Allen
Originally Posted by Doc2012
You can get one of these. I've been running one for a long time.
It's a power amped antenna. Sticks to the inside of the windshield.
This is what I have and I love it....
I still need to cover that hole, what are you guys using?
03-25-2014, 05:58 PM
#23
My antenna (mast) is broken too. Upon turning the truck on/off, the motor makes noise for a few seconds. I want to at least disconnect it, and I would ideally like to replace or fix it.
Here is my question...
My radio reception is still really good. I have an aftermarket stereo that was installed before I bought the truck. Have others found that their reception is still good, even after the stock antenna mast breaks?
Originally Posted by Bump N Run
What is this you say about a rear window antenna?
03-25-2014, 06:23 PM
#24
Real Name: Mark
Real Name: Mark
Originally Posted by Gerdo
Run the stock one up, unplug it (behind the inner fender liner) and leave it up.
If it won't come up, grab it and yank it up.
This is exactly what I did on my 97 Limited and my 99 Limited. When the "inner-workings" finally gave out, I got so tired of hearing that darn motor running every time I fired up and shut down the truck - I pulled up the antenna and unplugged the motor. Done deal.
Good call, man!
2007 Sport Edition 4Runner
03-25-2014, 06:26 PM
#25
In general when we are talking about the mast breaking, we mean the white plastic gear strip INSIDE the mast breaks or no longer engages with the drive motor gear so the metal part of the antenna is intact, but does not go up and down. In this case, as long as you can leave it extended, reception is unchanged.
If you actually break the metal part of the mast, reception will be affected, but less so if the diversity antenna is connected. In some situations, it will make no difference at all, but in most it will do better with both antennas at work.
The rear window antenna is explained in the linked thread, but they are fine wires in your cargo area side glass (I forget which one.) Take a look, it's there.
My Backyard Frame Swap
03-25-2014, 07:09 PM
#26
Thanks. I know about the wires in the back window that you are talking about, I just didn't know what they were for. They are on the passenger side on my 4Runner.
The antenna in the front is gone. The motor runs and does nothing. There is no antenna to raise or lower. The reception is still good.
03-25-2014, 07:15 PM
#27
I would guess that's a stock radio and it is doing fine with the diversity antenna, unless you live quite close to the broadcast antennas and you get reception on your teeth fillings.
I'd buy a raderra mast and try to install it. You may have to remove the antenna motor and clean out plastic pieces left behind.
03-06-2015, 04:19 PM
#28
Real Name: Tyler
Real Name: Tyler
My antenna just snapped off in an accident, and I just ordered the shorty. Mind helping me out with the kind of antenna kit I should be looking for. The metra site has quite a few. thanks!
2001 Limited (gone), 2012 Trail Edition. South Carolina.
"Impossible isn't a fact, it's an opinion."
03-06-2015, 08:45 PM
#29
I bought the one from antennamastsrus from Amazon I think it was. Works perfectly. The cheaper ones from Ebay have smaller teeth and don't work properly. It's great to have a power antenna that works. Make sure you turn off the radio IF you use automatic car washes. I don't use them except for the "bottom blasters" in the winter to remove salt and beet juice,etc.
03-06-2015, 10:29 PM
#30
It was the metra kit for the 2nd gen 4runner. I didnt use the bezel that came with it I just used the spacers the shorty antenna came with to retain the antenna stem position.
