03-06-2015, 11:52 PM
#31
Real Name: Paul
Real Name: Paul
Originally Posted by jreask
I bought the one from antennamastsrus from Amazon I think it was. Works perfectly. The cheaper ones from Ebay have smaller teeth and don't work properly. It's great to have a power antenna that works. Make sure you turn off the radio IF you use automatic car washes. I don't use them except for the "bottom blasters" in the winter to remove salt and beet juice,etc.
I agree. I have gone through two of them from EBAY. They both worked good for two days, then the teeth begin to grind!! Found that the teeth were smaller as you mentioned!
Get In - Sit Down - Shut Up - & Hold On
2002 4runner limited (supercharged) 7th Injector / Water-Meth Injection
03-22-2015, 11:43 PM
#33
Originally Posted by SC01
Looks like it I am not 100% sure since I lost my database with all my receipts, but look very similar. You may want to look into the taco whip mod before you do this though. I was broke when I did this frankly and it was intended to be temporary fix.
03-23-2015, 03:10 AM
#34
Real Name: Frank Giron
Broken antena
i have replace my other vehicles antena like the one shown by Doc2012 they are very reliable and easy to install and i remove my headache of listening the old antena motor humming unand down evvery time i turn on and off my vehicle
03-23-2015, 03:57 AM
#35
Originally Posted by tek9
I ditched the whole external antenna. In my case reception from the passenger window built-in antenna is good enough. Bought a rubber cover for the fender hole and never looked back.
I eliminated my whip antenna on my first-gen. Now I'd like to remove the base from the fender. May I know which plug you used on yours?
TIA,
RAD
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
03-23-2015, 09:00 AM
#36
Can anyone post some pics of their fixed antennas? There's a surprising lack of pictures for this. I really want to replace my broken power antenna with a fixed one but I'd like to see how it looks first.
Also, any cheap replacement ideas are appreciated.
2000 SR5
03-23-2015, 11:21 AM
#37
Not trying to steal a thread, but has anyone had any luck replacing the entire antenna motor?...how hard was it to feed new antenna wire to the radio? When I bought my 2001 the previous owner removed the motor...
03-24-2015, 12:14 PM
#38
Real Name: Tyler
Real Name: Tyler
Yea I've been reading a lot of threads about it. I also tracked down the Toyota part number to the fixed base and most places want around $60 or more if I remember correctly. I'd prefer the cheapest route possible to get this done. Appreciate the insight. It's been a big help.
2001 Limited (gone), 2012 Trail Edition. South Carolina.
"Impossible isn't a fact, it's an opinion."
09-26-2016, 08:52 PM
#39
Originally Posted by Doc2012
You can get one of these. I've been running one for a long time.
It's a power amped antenna. Sticks to the inside of the windshield.
Where did you find this antenna? I can't seem to find anything good that won't cost me an arm and a leg. If need be ill do the taco whip conversion but that is quite pricey as well
'99 Runner. Manual. Limited. Daily driver+project.
09-26-2016, 09:21 PM
#40
Real Name: Throws like a girl
There should be an antenna in your right side cargo window if it's a 99. It looks like orange lines in the glass. An adapter would allow you to use it instead of the fender antenna, or in conjunction. A switch in the front antenna to choose when it goes up or unplugging it or repairing or replacing as needed are all options there.
Rock Slide did an awesome write-up for enabling the rear antenna.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
09-27-2016, 11:13 AM
#41
Real Name: Mark Hansen
Junkyards / CAR-PARTS.com/ Ebay
I just got done doing both of mine. I went to a you pull it junk yard and found that 1/2 of the 4runners there still had the power antenna on it. The motor is never going to fail unless it gets flooded/corroded. The main problem is the plastic parts in the unit and attached to the mast. There are gears inside it that get brittle and the plastic gear on the mast breaks. All the work is easy and replacement antennas are all over eBay. I like OEM better but I did just buy one of the 12.99 antenna masts and it seems ok. We will see how long it lasts. The junkyard route is the best way to go as the parts are very cheap. I paid 15.00 for the whole units I pulled from the Junkyard. On a side note It is very hard to pull the coax cable from the dash as after it goes up into the dash it has some retaining clips. I chose to cut/splice the cable after I got a whole cord and cut my hands up pretty good from the dash and broken glass. I hope this helps.
09-27-2016, 11:56 AM
#42
Location: Stationed in Camp LeJeune, home is Conover, NC
You can get them at an audio shop, or Ive seen them on Amazon.
They're about 30 bucks or so.
Another option, if you have a CB, is this thing.
Bought it a few weeks ago and works amazingly.
https://www.amazon.com/gp/aw/d/B00HP...?ie=UTF8&psc=1
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
09-27-2016, 12:49 PM
#43
TIA,
RAD
There is also the OEM Toyota antenna hole cover used on the base models as an option on 3rd gens. It's p/n 55796-89102. I don't know if it would fit a first gen but I thought I'd post for the others that may do this. Should be about $4 at your friendly local stealer:
55796-89102 - Genuine Toyota COVER, RADIO ANTENNA HOLE
Obviously, he'll have to order it. Not a stock item.
My Backyard Frame Swap
09-27-2016, 03:25 PM
#44
I ended up replacing the antenna itself, found out my 96 had broken plastic teeth.. I went on amazon and got a new one, only to find out after a week it would grind because it wasn't getting into the gears.. I like the Power idea for if I go offroad and I don't snag. right now I just unplugged the power from the motor and it stays up all the time. until I get it replaced.
09-27-2016, 03:39 PM
#45
Real Name: Just call me the Grease Monkey
My 97 antenna still works but I find it annoying going up and down all the time and I know that at some point it's going to break so I want to replace it with a fixed one. But I don't like that location since it will get wrecked by thick brush. Does anyone know of somewhere else you can mount it further back on the car and have it pointing back on an angle? Or maybe I'll just put in one of those that were shown on the first page that go inside beside the front windshield but it would be nice to keep that area clear. I guess I could mount one of those anywhere.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
