12-23-2014, 06:12 PM
#31
Real Name: Robert
Real Name: Robert
How To: Monitor Trans Fluid Temp (and other things) On Your iPhone
Just an update.
I'm now using an iPhone 5 as I've now retired my old dependable iPhone 4.
The iPhone 5 is running iOS 8.1.2, jailbroken with TiaG. I then reinstalled RoqyBT7, and RoqyOBD7. At first I was having issues with Engine Link not finding the OBD2 dongle. Everything still worked fine on my iPhone 4, so I knew something was up with my iPhone 5. After Googling, I found Roqy's Facebook page, and they had a post stating to make sure you rebooted your phone if you jailbroke with TiaG. Doh! So I rebooted and everything works again. Be sure to reboot after you jailbreak!
Screenshot of my current gauge setup:
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
12-24-2014, 03:37 PM
#32
Real Name: Robert
Real Name: Robert
I went back and added to the original post. Now there's a write up included for how to monitor your Air Fuel Ratio. This only applies to vehicles with an AFR sensor instead of the traditional narrowband O2 sensor.
Here's the new section of the write up:
Originally Posted by Robb235
How to Monitor Air/Fuel Ratios (California Emissions Vehicles Only)
Ok, so yesterday I was fooling around with how to read AFR on Engine Link. I've got a '99 4Runner that has California style emissions, which means that there is a an "Air Fuel Ratio Sensor" instead of the normal narrowband oxygen sensor. To see if you have an Air Fuel Ratio Sensor equipped on your rig, take a look at your exhaust pipes, and if you have 2 catalytic converters, you've got the wideband AFR sensor. If you only have 1 catalytic converter, then you've got the narrowband sensor, meaning this part of the write up will not work for you (sorry).
Some 4Runners have the ability to monitor the air fuel ratio directly from the ECU. All that's needed is a custom PID and formula. This only works on some rigs, while it doesn't work on others. Unfortunately this did not work on my '99. I suspect it only works on 2001 and newer, but I'm not positive. At any rate, try the following custom PID and see if it works for you:
ECU address or Header: 0
ModeandPID: 0124
Formula: A*(1465/80)
Min Value: 10
Max Value: 20
Description: Air Fuel (or water you want to call it)
Unit: Ratio
If the above works for you, then you're finished. However, if you're like me and the above does not work for you, there's another, more roundabout way to view your AFRs.
Using this method, we're going to create two new custom PIDs. One will be for lean AFRs, the other will be for rich AFRs. Create the following:
ModeandPID: 0114
Formula: A*(15/200)+4.8
Min Value: 10 (or however low you want it to go)
Max Value: 14.7 (this MUST be 14.7)
Description: AFR (Rich)
Unit: Ratio
ModeandPID: 0114
Formula: A*(30/200)-5.1
Min Value: 14.7 (this MUST be 14.7)
Max Value: 20 (or however high you want it to go)
Description: AFR (Lean)
Unit: Ratio
Now that you've created your two custom PIDs (one for "rich" and one for "lean") go back to your gauge screen. Hold down on the gauge screen until the menu pops up, and select "Big Bar" (selecting "Small Bar" will work too). Place the AFR Rich gauge on the left side of the screen. Do the same thing again, and place the AFR Lean on the right side of the screen, as pictured below:
Now you can monitor what your actual AFRs are. When you're rich, only pay attention to the value on the "Rich" gauge. And when you're lean, only pay attention to the value on the "Lean" gauge.
Here I'm running right at 14.7
Here I'm running at 13.12 (ignore the 11.55 value)
Here I'm running at 15.6 (ignore the 15.15 value)
Hope that helps! Let me know if you have any questions.
01-15-2015, 02:12 PM
#33
So is there a consensus on the formula?
Is it: Formula: A*(9/5)-38 or is it Formula: A*(9/5)-40
01-15-2015, 02:37 PM
#34
This is awesome info guys. Thanks for figuring this out with the trans temp. It's working like a charm on my 00' Limited.
I browsed through the thread again and didn't stumble upon a way to monitor fuel level. Am I correct at understanding the 00' Limited does not provide this through ECU feedback?
2000 TacoRunner Limited
SS 1.2A, 4 Crawler 2", 305/70R16, G2 4.88 gears, Cobra 19dx iv, factory locked, Tru-Cool 4454 tranny cooler, 4" deckplate, ISR mod, 04' Tacoma Front end swap, CBI rear bumper with swing out, 4xinnovations custom sliders
01-16-2015, 07:31 AM
#35
Real Name: Robert
Real Name: Robert
Probably the -40 one is correct, but decoding the Scangauge code came out to be -38. Either way, it's only a couple degrees different.
Unfortunately the fuel level doesn't get reported to the ECU, it just goes straight to the gas gauge.
01-22-2015, 10:10 AM
#36
This may be a stupid question, but I'll ask anyway.... How do you know which info to look at, rich or lean? On the gas rich? Coasting look at lean?
Black 99 highlander. toytec ultimate lift with bilstiens, and diff drop. 255 85 BFG KM2's, and tundra 231mm brake mod to stop them. ISR, and deckplate mod, rear diff breather. Front ARB locker and compressor. Scan gauge 2. Yakima mega warrior. Savage rear with swing out. AND NOW....SC'D!!
01-22-2015, 11:04 AM
#37
Real Name: Robert
Real Name: Robert
If it's running right at stoich, both gauges will read 14.7. If it's running lean, look at the lean gauge only. If running rich, look at the rich gauge only.
I should probably explain in more detail.
Take a look at the graph below. For rigs that have the wideband O2, you can match up the voltage reading of front O2 to the AFR that it corresponds to.
Notice that on the rich side of the graph, every 0.1v increment correlates to a 0.3 change in AFR. Now take a look at the lean side of the graph. Notice that every 0.1v increment now results in a 0.6 change in AFR. This change in the slope of the line is the reason for having two gauges, one for rich and the other for lean.
Hope that makes sense.
12-29-2015, 12:11 AM
#38
Real Name: Connor
Real Name: Connor
So to clarify, my 4Runner is what I think would be designated as a 98.5 Limited... do I have the necessary trans temp sensor to monitor the running temp or do I just have the sensor for the idiot light??
'99 4Runner - '00 Yamaha WR400F - '03 Suzuki SV650
12-29-2015, 06:59 AM
#39
Real Name: Robert
Real Name: Robert
Do you have the '99+ upgrades? "Fat lip" bumper, cup holders in the center console, etc.?
12-29-2015, 11:46 AM
#40
Real Name: Connor
Real Name: Connor
Yes, those, the multi-mouse 4WD, along with everything else listed in the upgrades for the 99 model year.
On a side note, I tried out the PID for transmission temp listed at the beginning of this thread (-40, not -38), and it was telling me there was no data, but there were two other Trans temp sensors that came with Torque Pro, and the second one was reading a temp. Would that be it? I didn't run my truck for long to see what kind of operating temps I would get, but I'll be doing some driving around here in a couple hours so I can see what it'll read.
12-29-2015, 03:00 PM
#41
Real Name: Robert
Real Name: Robert
Sounds like your 4Runner is similar to mine; '99 Limited model with multi-mode. You should have the transmission temp info available to you.
I'm not familiar with Torque Pro, as I think that app is for Android phones (I'm using Engine Link for the iPhone). What PID is registering as transmission temp for you?
12-29-2015, 03:45 PM
#42
Real Name: Connor
Real Name: Connor
Disregard what I said in my first post, it was my mistake why the added PID want working, I had one of the numbers in wrong. I'm now seeing transmission temps!! Yay!
12-29-2015, 04:03 PM
#43
Cool thread. I may switch back to Iphone, so it is nice to see there is an option for this.
Is there a sensor for oil temp or oil pressure?
Never could get one for Torque/Android.
I was led to believe it was not available, but didn't know if one day it might be possible.
Thanks for everyone's hard work on this!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
12-29-2015, 05:29 PM
#44
Real Name: Robert
Real Name: Robert
Good deal, glad it's working.
12-29-2015, 05:31 PM
#45
Real Name: Robert
Real Name: Robert
As far as I'm aware, there isn't an oil temp sensor on our rigs. I believe the oil pressure sensor only goes to the dummy light and does not report to the ECU, so there's not a way to view that info via the OBD port.
