Old 01-29-2014, 12:33 PM #1
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
How To: Monitor Trans Fluid Temp (and other things) On Your iPhone
For quite a while now, Android phone users have had the option to use Torque Pro to monitor live engine data, including transmission fluid temperature (on '99 and new 4Runners). I started a thread here, but didn't find anyone who had done this before with the iPhone. After doing some internet reading, I came up with the following steps:
Step 1: The app I used is called Engine Link. I'm in no way affiliated with the developers of that app, but it's the only one that I'm aware of that monitors live engine data, and also allows for adding custom PIDs (which you will need to do to monitor transmission temp). Go to the Apple App Store and install the Engine Link App. It's about $5.
Step 2: Next you'll need a device that plugs into your vehicle's OBD2 port, and transmits the data wirelessly. You have two routes you can go with this. Either you can get a Bluetooth adapter, or a WiFi adapter.
WiFi Adapter: The WiFi adapter is the easier of the two. It doesn't require jailbreaking of your iPhone. The downside is, if you use the WiFi adapter, you will lose data connection to your phone. When connected to the WiFi adapter, your phone will be looking for an internet connection, which obviously that OBD2 adapter won't be providing. You can pick up these adapters off Amazon, just make sure that it has ELM327.
Bluetooth Adapter: This is the route I took. The Bluetooth method is a little more complex, however the advantage is that by using Bluetooth instead of WiFi, your phone will still have access to data, whether it's from 3G, 4G, EDGE, etc. For whatever reason, Apple products don't always play nice with Bluetooth, so for this reason, you will need a jailbroken device that has access to the Cydia store (store for jailbroken phones). Jailbreaking your iPhone is outside the scope of this write-up, so if you need instructions on how to jailbreak, I suggest using Google.
In Cydia, you will need to download and install an app called RoqyBT4. This is what will allow your iPhone to "talk" to the Bluetooth-OBD2 adapter. Once installed on your phone, open up RoqyBT4 and follow the instructions for purchasing a license. I paid $7 for mine through Paypal. Once that is complete, go back to Cydia, and download the add-on app called RoqyOBD4. There is no additional cost for downloading the RoqyOBD4 expansion.
Once you've completed the above, you will need a Bluetooth OBD2 adapter. I used one made by BAFX, and bought it off Amazon for $24.
Step 3: Next, we need to connect your iPhone to the OBD2 adapter. These instructions will be geared towards using the Bluetooth adapter, since that is what I used. Wifi adapter should be pretty easy to figure out.
Now that you have the Engine Link app, and your OBD2 adapter, plug in the adapter to your OBD2 port in your vehicle. Make sure your vehicle is running. If using the Bluetooth adapter, open up RoqyBT4, and turn Bluetooth on. For me, the OBD2 adapter was listed as "OBDII" on my list of devices to connect to. Connect to your OBD2 adapter. When the screen pops up telling you that you're connected, take note of the IP address and the port that it connects to. For me, the IP Address is 127.0.0.1 and the port is 35000.
Now open up your Engine Link app. You can swipe left and right to get different screens, however the first screen you see should be the one that connects you to your OBD2 adapter. Enter in the Adapter IP Address and Port Number as noted above, and then hit Connect. It should connect in a few seconds. Swipe the screen to the right and you should see various live engine data.
Step 4: This step will document how to view the transmission temperature fluid (TFT for short) on '99+ 4Runners. You'll notice that Engine Link doesn't immediately have a PID for the trans temp. If you keep swiping to the right, you should find a screen that says "Long press to create or move the custom PID". Hold down anywhere on the screen, and a window will pop up that says "Add New Display Cell". Usually I pick the one that says "Big Digital", but pick whichever one you like. Here you'll see a bunch of PIDs, such as Calculated Engine Load Value, and Engine Coolant Temperature. However, you'll notice that Transmission Fluid Temperature isn't listed here either. You are going to have to add it in.
To add in TFT, click on "Edit" and then plus "+" on the left side of the screen. Enter in the following information:
ECU address or Header: 0
ModeandPID: 01B4
Formula: A*(9/5)-38
Min Value: 0
Max Value: 300
Description: (I used TFT, but you can put in whatever you like)
Unit: F (if you want, you can put in the degree sign so it's °F).
Your new PID that you just created is now at the bottom of the list of PIDs.
I chose to use my iPhone instead of a Scangauge2 because I didn't want to mount a permanent gauge anywhere in the cabin. This method is also much cheaper than a SGII.
Please post up any questions and I'll be happy to help out.
EDIT 12/24/14: How to Monitor Air/Fuel Ratios (California Emissions Vehicles Only)
Ok, so yesterday I was fooling around with how to read AFR on Engine Link. I've got a '99 4Runner that has California style emissions, which means that there is a an "Air Fuel Ratio Sensor" instead of the normal narrowband oxygen sensor. To see if you have an Air Fuel Ratio Sensor equipped on your rig, take a look at your exhaust pipes, and if you have 2 catalytic converters, you've got the wideband AFR sensor. If you only have 1 catalytic converter, then you've got the narrowband sensor, meaning this part of the write up will not work for you (sorry).
Some 4Runners have the ability to monitor the air fuel ratio directly from the ECU. All that's needed is a custom PID and formula. This only works on some rigs, while it doesn't work on others. Unfortunately this did not work on my '99. I suspect it only works on 2001 and newer, but I'm not positive. At any rate, try the following custom PID and see if it works for you:
ModeandPID: 0124
Formula: A*(1465/80)
Min Value: 10
Max Value: 20
Description: Air Fuel (or whatever you want to call it)
Unit: Ratio
If the above works for you, then you're finished. However, if you're like me and the above does not work for you, there's another, more roundabout way to view your AFRs.
Using this method, we're going to create two new custom PIDs. One will be for lean AFRs, the other will be for rich AFRs. Create the following:
ModeandPID: 0114
Formula: A*(15/200)+4.8
Min Value: 10 (or however low you want it to go)
Max Value: 14.7 (this MUST be 14.7)
Description: AFR (Rich)
Unit: Ratio
ModeandPID: 0114
Formula: A*(30/200)-5.1
Min Value: 14.7 (this MUST be 14.7)
Max Value: 20 (or however high you want it to go)
Description: AFR (Lean)
Unit: Ratio
Now that you've created your two custom PIDs (one for "rich" and one for "lean") go back to your gauge screen. Hold down on the gauge screen until the menu pops up, and select "Big Bar" (selecting "Small Bar" will work too). Place the AFR Rich gauge on the left side of the screen. Do the same thing again, and place the AFR Lean on the right side of the screen, as pictured below:
Now you can monitor what your actual AFRs are. When you're rich, only pay attention to the value on the "Rich" gauge. And when you're lean, only pay attention to the value on the "Lean" gauge.
Here I'm running right at 14.7
Here I'm running at 13.12 (ignore the 11.55 value)
Here I'm running at 15.6 (ignore the 15.15 value)
Hope that helps! Let me know if you have any questions.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 01-29-2014, 03:01 PM #2
criera's Avatar
criera criera is offline
criera is on a distinguished road
criera's Avatar
Thanks for putting this in writing. I just got a wifi only ipad dialed in using the jailbreak/bluetooth option. Works great.
As an added bonus bonus, the roqy BT license allows install on up to 3 devices. so my iphone is JB, tethered to ipad for data, and now I can use a $20 10 yr old tomtom bluetooth gps on either iphone or ipad allowing full nav on the ipad, or a big power savings on the phone by not using its internal gps.
My only potential drawback is this. I am also running a scan gauge so I'm using an obd splitter, I think I might be experiencing intermittent data drops to th SGII when the BT obd is running concurrently. At my last fillip the SG reported 5 miles differently then the car trip meter which has always been an exact match. Also the SG seemed to have a little intermittent latency which it's never had before.
I'll have to keep an eye on that. I don't ever ask a lot, don't know why I can't have my cake and eat it too lol.
Anyways nice write up!
2000 SR5 V-6 Auto
criera is offline   Reply With QuoteReply With Quote
Old 01-29-2014, 03:31 PM #3
Ryan_289 Ryan_289 is offline
Ryan_289 is on a distinguished road
Is their an option for the 96-98 models?
Ryan_289 is offline   Reply With QuoteReply With Quote
Old 01-29-2014, 03:57 PM #4
PNW yota's Avatar
PNW yota PNW yota is offline
PNW yota is on a distinguished road
PNW yota's Avatar
Pretty cool! wish I'd have known about this before ordering my interceptor gauge. Much cheaper way to go!
2000 Limited: Multi-mode (VF3AM), E-locker, TRD SC & exhaust, URD 7th injector, AIC/Timing Calibrator, Denso IK22, AT bypass, onboard air with rear bags, Tundra brakes. Hella 500FF. CB. Full weathertechs. '02 fascia upgrades, GaugePodx2 w/ boost+Aeroforce, Sport hood.
PNW yota is offline   Reply With QuoteReply With Quote
Old 01-31-2014, 02:57 PM #5
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
I'll have to play around with connecting my iPhone to an old Garmin unit I have.
As far as your data drops go, I think it has something to do with our rigs using the ISO OBD2 protocol. If I'm not mistaken, because of ISO, the more PIDs you monitor, the slower the refresh will be. That would certainly explain your mileage variance.
Unfortunately no. Tranmission temperature isn't reported to the ECM on '98 and older models. From what I've read, this seems to hold true across the board for most (all?) Toyota trucks, including T100, Tacoma, and Landcruiser.
Old 03-23-2014, 01:26 AM #6
JeremyB JeremyB is offline
JeremyB is on a distinguished road
ModeandPID: 01B4
Formula: A*(9/5)-38
Min Value: 0
Max Value: 300
I was searching for the tranny temp for a neighbor's '01 Land Cruiser and came up on this thread.
Your formula has a small error, it should be A*(9/5)- 40 instead of A*(9/5)-38. Your formula will give you a constant 3.6 deg F positive offset error.
JeremyB is offline   Reply With QuoteReply With Quote
Old 03-23-2014, 07:19 AM #7
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Just curious, how did you come up with -40 instead of -38?
Old 03-23-2014, 11:06 AM #8
-40 is the 'standard' minimum temperature for any OBD sensor. OBD-II PIDs - Wikipedia, the free encyclopedia
Coolant, Air Intake, Engine Oil, Ambient Temp all use A-40 as their equation.
Old 03-24-2014, 07:35 AM #9
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
It's possible you're right.
How I came up with the formula was that I took the Scangauge 2 "codes" and found a guide on the internet describing how to convert them to the decimal formula that Engine Link and Torque Pro use. The formula I came up with hinges on how accurate the Scangauge one is.
Old 03-24-2014, 07:51 AM #10
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
For some reason in Engine Link, Mass Air Flow (MAF) is only listed in grams per second. For me, I prefer pounds per minute. To add MAF in units of lbs/min, add the following custom PID:
ModeandPID: 0110
Formula: (((A*256)+B)/100)*(1/7.55983)
Min Value: 0
Max Value: 30
Description: MAF
Unit: lbs/min
Old 03-24-2014, 01:18 PM #11
A-40 is definitely right.
Nearly all of the XGauge codes come from the user community. All their Prius codes (which is a small slice of all the actual codes available) come from Priuschat and the like using telnet to read the raw data.
Somebody must have screwed up the transcription of the code at some point. -40 is the default minimum temp for sensors. -38 makes no sense.
Old 03-24-2014, 03:33 PM #12
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Makes sense.
At any rate, seems you know more about this stuff than your average Joe. Got any other good information, or other PIDs you'd like to share?
Old 03-24-2014, 06:04 PM #13
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
@JeremyB , do you happen to know whether or not your neighbor's Landcruiser has "Air Fuel Ratio sensors", which are pretty much wideband O2 sensors? I'm wondering what happens if you add the custom PID below:
ModeandPID: 0124
Min Value: 0
Max Value: 30
Description: AFR
Unit: Ratio
Old 03-24-2014, 06:45 PM #14
Makes sense.
For the 3rd gen, not too much.
My wife has a 5th Gen, but I haven't been able to spend much time messing with it. Currently I've taken the Gen III Prius PIDs and figured out which work on the 4Runner. There are still several 5th Gen 4Runner specific PIDs that I need to figure out, which is the hard part. That and my TechStream refuses to talk to my Powertrain ECU, which is where all the PIDs I want are! Wife goes on travel soon, so I'll be able to spend some time on it in a few weeks.
ModeandPID: 0124
Min Value: 0
Max Value: 30
Description: AFR
Unit: Ratio
If he wants me to see what his tranny temp is, I'll try out the O2 PID too.
Looks like it is a standard Mode 1 PID. Won't be hard to look at. I'll take a picture of the "Available Sensors" to show what all Mode 1 PIDs are available.
Old 03-24-2014, 08:10 PM #15
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Can you post some sort of overview on how you identify PIDs, and then how you go about determining the formula, and what sensor it's monitoring? Or is it going to involve an in depth lesson in programming and hexadecimal?
Scangauge trans temp? macoyle 4th Gen T4Rs 74 05-27-2023 08:29 PM
Scangauge II for trans temp? Tdaz250 3rd gen T4Rs 12 10-03-2016 09:26 PM
Good iPhone app to monitor trans temp? Robb235 3rd gen T4Rs 38 02-19-2015 10:22 PM
Trans Fluid change and 4wd fluid?? PaulZ 4th Gen T4Rs 9 01-09-2013 02:39 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
