Originally posted by Lexusbstrdchild
its easy to remove the headlight, the PITA is removing the front grille. you have to remove that, in order to get to the nuts on the headlight. you will also have to remove the turn signals to get to another nut. the signals pull straight out with a little persuasion. then the painted metal panels below the headlight also have to go. but its not too bad.
I think I will just live with the little rock chip. It seems like it is staying dry inside.
Thanks to all for responding.
