Old 02-06-2018, 04:55 PM #1
Friday88's Avatar
Friday88 Friday88 is offline
Friday88 is on a distinguished road
Friday88's Avatar
Hard Brake Pedal During Panic Stops - Brake Booster?
I discovered an issue with my braking system when a vehicle pulled out in front of me today. The pedal was rock hard and required a lot of force to get it down far enough to actually engage the brakes. This does not happen when I brake under normal stopping conditions, it only happens when I quickly try to press the brake pedal down hard.
I recently changed the brake hoses and put all new fluid in the system and bled it correctly with a partner. The pedal feel improved after I did that so I don't think it's related.
I'm wondering if my brake booster is failing? I've read that a hard pedal is one of the symptoms but I'm not sure since the hard pedal is only during hard stops. Any thoughts or advice is appreciated, thanks.
Friday88 is offline   Reply With QuoteReply With Quote
Old 02-06-2018, 09:40 PM #2
thecole1098's Avatar
thecole1098 thecole1098 is offline
thecole1098 is on a distinguished road
My old 99' had this issue and a new brake booster seemed to fix it. When you go to replace it, make sure there's not evidence of brake fluid inside as that will obviously be the root problem and will mean the seal of the MC is allowing it to leak into the booster.
'06 4Runner SR5 V8 2WD -- Flowmaster 50 Delta Series w/ resonator delete | 265/70R17 Toyo Open Country A/T | Pro Comp Series 5044 | Black headlights
'98 Jeep Cherokee Classic -- Fender armor | 35x12.5x15 Pro Comp MT2 | 4.5" RE short arm lift | Locked | Swingout Plate Rear Bumper | Shackle Relocation Kit
thecole1098 is offline   Reply With QuoteReply With Quote
Old 02-06-2018, 10:31 PM #3
Scottyboy Scottyboy is offline
Scottyboy is on a distinguished road
I have this issue too, but only in the winter when it’s freezing. Like -25 to -30 Celsius. In the summer and at any other temperature it’s perfectly firm and not spongy at all
Scottyboy is offline   Reply With QuoteReply With Quote
Old 02-07-2018, 09:46 AM #4
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Sounds like a failing brake booster check valve to me. Mine did the exact same thing on cold mornings.
Make sure you replace the grommet that check valve sits in also.
It's only like 25 bucks for both parts, I'd start there.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 02-07-2018, 09:58 AM #5
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
I had a booster leak . slowly the leak engine on got bigger so at first it did seam a bit hard to press down on a faster harder stop.. then normal easy braking pedal high and hard.. booster was worn over 200K on it..
with the engine off for an hour press down on brake if high and hard its a leak...
master fluid leak into it also causes the seal to break down as well as time and use ..
catrains is offline   Reply With QuoteReply With Quote
Old 02-07-2018, 10:19 AM #6
Friday88's Avatar
Friday88's Avatar
The valves can be replaced by themselves? I figured I'd have to replace the whole booster assembly which is pretty expensive.
Old 02-07-2018, 10:20 AM #7
Friday88's Avatar
Friday88's Avatar
I think I'll probably rebuild the MC anyway if I'm in far enough to replace the booster assembly.
Old 02-07-2018, 11:30 AM #8
thegipper's Avatar
thegipper's Avatar
What year is your rig?
I believe the 01/02 its all one assembly.
The check valve on the brake booster on the 96-00 can be removed and replaced. It's stupid simple, takes 5 minutes.
2011 Camry SE V6
Old 02-07-2018, 11:59 AM #9
SpidermanGeek's Avatar
SpidermanGeek SpidermanGeek is offline
SpidermanGeek is on a distinguished road
This is 100% the Brake Booster Check Valve if you have a '96 to '00.
These were the parts I ordered for my '97 Limited
1- VALVE ASSEMBLY, VACUUM CHECK (FOR BRAKE) . VALVE,CHECK [44730-60060]
1- GROMMET, CHECK VALVE [90480-24015]
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
SpidermanGeek is offline   Reply With QuoteReply With Quote
Old 02-07-2018, 03:22 PM #10
Friday88's Avatar
Friday88's Avatar
AWESOME! Thank you.
I have a 96. I'll order these parts today.
EDIT: McGeorge Toyota's website says the grommet doesn't fit my 96. Should I assume that's incorrect?
Old 02-07-2018, 03:58 PM #11
Originally Posted by Friday88 View Post
AWESOME! Thank you.
These 3 part numbers should be the same part (all were replaced by/redirect to 90480-24015)
  • 90480-24438
  • 90480-24517
  • 44673-25020
Does the site give you one of those?
Old 02-07-2018, 04:23 PM #12
Friday88's Avatar
Friday88's Avatar
  • 90480-24438
  • 90480-24517
  • 44673-25020
That first one says it fits. Perfect, thanks man.
Old 02-07-2018, 04:46 PM #13
test the check valve and hoses for leaks . check valve flows one way easy to test .
Old 02-07-2018, 05:07 PM #14
Andy in Pa Andy in Pa is offline
Andy in Pa is on a distinguished road
Very interesting, my 99 does this at first on cold mornings, but then it goes away. I'll have to look into this as well.
Andy in Pa is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 02:08 PM #15
greeney greeney is offline
greeney is on a distinguished road
Hard Brake pedal:
Updating this thread to inform that I replaced my brake booster and have some suggestions. The most difficult part was inside the car. 3 of the nuts were easy, but not the upper right nut which is partially blocked by the brake pedal. I removed it with a socket wrench with 3" extension and DEEP 12mm socket, approaching from the door side of the steering column. To re-install, I had to get the nut started by holding it between 1st and 2nd finger to place it. Will be tough with big hands and don't drink too much coffee. Also you will drop it into the rubber boot around the steering shaft. Fortunately that is held on by velcro. But of course it will then fall behind the carpet and you will pull that up to fish around for it there.
Bad news is I still have the same hard brake pedal when making a downhill stop. Braking feels good for first 3/4 of the stop but by last 1/4, to come to FULL stop, I'm standing really hard on the pedal. Sigh
greeney is offline   Reply With QuoteReply With Quote
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Strange brake issue - hard pedal Renton4runner 3rd gen T4Rs 22 11-15-2019 04:11 PM
Brake pedal hard to push down shoota 3rd gen T4Rs 40 04-23-2019 09:26 PM
Did tundra brake upgrade and brake pedal mushy. 3rdgenfan 3rd gen T4Rs 5 10-25-2015 08:51 PM
Brake pedal hard to push? jarnld Classic T4Rs 5 05-14-2008 12:59 PM
