04-18-2017, 07:32 PM
#46
Real Name: Matt
Real Name: Matt
97 4Runner SR5 5 Speed Swap, ARB bumper - Warn M8000 winch - Custom rear bumper w/ tire carrier - Dual Jerry Can Carrier - Dual Optima Batteries - BlueSea Battery Isolator and Charger -Rear E-locker retrofit- ARB Front Locker - ARB Compressor - Hiflow exaust - ISR/deckplate mod - Trail Gear sliders - Tepui Kukenam Rooftop Tent - JDM Field Monitor Unit - 170 Amp Alternator - Bilstein 5125's - OME 861's - Toytec Coilovers - Camburg UCA's - 1" Toytec BL - 315/75/16 STT Pro's on Tacoma TRD wheels
04-18-2017, 09:47 PM
#47
I would love one of these tents!
04-19-2017, 09:54 AM
#48
The Defenders are almost exactly what I envisioned!
Stockwell45 - did you locate the extrusions on the tent base yourself? Mine came with pre-drilled holes that would make it impossible to do what you've done.
04-20-2017, 07:18 PM
#49
Real Name: Matt
Real Name: Matt
My tent came with pre-drilled holes as well. These holes were for running the bolts through to mount the rails. The dealer at the Tepui warehouse helped me mount the rails. I bet you could call Tepui and order a set of rails, and just mount them yourself. Then you could just patch the existing holes you have.
03-17-2018, 12:40 AM
#50
Bump for this thread, still looking to pick one up, any pros or cons?
04-06-2018, 09:34 AM
#51
I've used the defender mounts suggested here on several trips over the last 3 years. My truck is a 1999 4runner. The tent is a Tepui Kukenam Sky. No issues, and the setup is pretty easy. I check all the bolts regularly. On my last trip, a couple of them worked themselves loose.
I have made these videos about my experience with the Tepui Kukenam Sky:
Part 1: https://youtu.be/KtzCk7DVAk4
Part 2: https://youtu.be/9qhH9CsM4EA
04-24-2018, 12:03 PM
#52
I'm planning on mounting my tent as you did with the Defender mounts. Just wanted to clarify: The pre-drilled holes would not work to mount the rails in the correct place, so did the dealer help you drill new holes so that once the rails were mounted, they would match up with the Defender mounts? Thanks for all your info!
06-11-2018, 05:03 PM
#53
Real Name: Matt
Real Name: Matt
Sorry, I did not see this until now. Hopefully this is still some help to you. The pre-drilled holes in the bottom of the tent to mount the rails are in the correct spot, I did not drill any new holes. When the rails are mounted, they line up perfectly with the Defender mounts on the roof. Unless the Tepui rail design has changed in the 5 years since I've had my tent, this should work for you too without having to modify your tent.
06-11-2018, 05:11 PM
#54
This is genius.
06-11-2018, 10:45 PM
#55
After wheeling last weekend. Being around people with RTT. I want one so bad ! And the more I think about it. The more I want a Tacoma 4door short bed. Because the once you mount the tent on the roof. You loose so much storage space !!! And on the Tacoma. You can mount it over the bed. And still have a roof rack over the roof.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
02-08-2019, 12:40 AM
#56
Real Name: Instagram: briansd_97r
Hey guys do any of you have a working link for where to buy the Defender Rooftop mounts that work with our 3rd Gen 4Runners?
I googled it but found ones that didn't look like a match at all to what is pictured in this thread.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
02-08-2019, 01:19 PM
#57
These are the closest to the ones in the original post I've been able to find.
https://www.amazon.com/Smittybilt-AM...smittybilt++am
03-19-2019, 09:05 PM
#58
Since I literally just got a RTT last weekend from the REI garage sale, can I ask you guys that have your tents mounts up w/ the aftermarket "L" brackets,
does the roof structure of the 'runner seem to be sturdy enough?
I just have my tent temporarily clamped to the factory X-bars so that I could move it from the store and into storage tomorrow until I figure out a study mounting system.
TIA for any feedback.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
03-20-2019, 05:24 PM
#59
I've got my Tepui Kukenam 3 mounted on the Tepui DIY rack. Seems pretty sturdy and has worked great so far
2000 4Runner 4x4 Limited - TRD Gen2 Supercharger, URD 7th Injector, Doug Thorley Headers, Shrockworks Front Bumper, Bilstein shocks, Durabumps, 315/75r16 Yokohama G003 M/T
1997 4Runner 4x4 5spd - OME 883 coilovers, 891/5100 extended travel rear, 4xInnovations Sliders, SCS Ray 10s, Falken Wildpeak AT3W 285/75r16 - SOLD
Track.n.trail on Instagram
03-20-2019, 05:36 PM
#60
Can you please post some pictures of how you mounted it on your 3rd gen. Also of this DIY rack.
Thanks
