Originally Posted by delta265
I'm not sure what an alignment dowel is. I will research and try to figure it out though, thanks for the heads up!
usually there are 2 small pins across from each other in the block, and corresponding holes in the bellhousing.
they align the engine to the transmission.
often times they get stuck, and even with all the bolts out, you have to pry the transmission back off the block. they sometimes have the same issue when putting it back together, making it hard to get seated fully. because of this...there are some people that will remove them, but that is a VERY bad idea.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
