Real Name: Mason
Real Name: Mason
spark plug change and cleaning. now nothing but problems. need help
Went over to a buddys house to change spark plugs and wires. While in there clean maf and throttle body. Everything went well. Turned it on. Exhaust spit some stuff out ect. Then when warmed up the rig would idle around 2000 rpm. We could not find anything wrong but read the iac sensor below the trottle body might have been gunked up during the cleaning.
By this time it was midnight so drove home. After the 25 mi drive rig would still idle at 1500 or 2000 rpm.
Next morning I un plugged the battery and the fuse to reset the computer. Came home and tested again but nothing changed. I took apart everything again. Disconnected the TB from the engine but left those two coolant lines in. Cleaned it again and reconfigured it to close all the way. I also sprayed so TB cleaner down in that hole that leads to the iac sensor. Put everything back together. I still have a high idle but now the rig seems like it is starving for air. When I first turn it on it stsrts at the normsl idle but thrn gets lowerand lower until it about dies. Both times I have hit the throttle I little and thst helps but it just goes bsck to the higher idle! When test driving rig sounds great when at the higher rpm. If I coast in first or second truck jumps likeit wants to stay at a higher rpm. When it let it idle and check the exhaust I hear a minor put put sound.
Nkw for the part that worries me. Engine mames a different sound like something is scraping. I can hear it expecally when I turn off the rig. For that last teo seconds of running the sound really comes to life.
Sorry about spelling or if something does not make sense. Typeing on a tablet and feel like im losing my mind over this 4runner.
might break down and bring it to a mechanic as the engine is 150 mi away from 200k and I dont want to f it up..
Mason
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
