Old 02-09-2014, 11:48 PM #1
baskelh's Avatar
baskelh baskelh is offline
baskelh is on a distinguished road
baskelh's Avatar
heater servo fix
Had the #2 heater servo strip out and no heat. All i heard was clicking under the dash. After checking prices on new and used i pulled it apart and started looking at a way to fix it. The gear only turns 90 degrees so i came up with a plan. There are two gold colored electrical conectors (brush type). One has 5 fingers on it and one has 6 fingers. Both are held in place by the plactic melted over the slightly. First i marked them 5 and 6. Then i shaved the plastic off them and removed them. Next drill small...very small holes where the plastic was melted down. Put five finger connector on mark 6 and vise versa. Use small screws to reattach them. Clock the gear over 180 degrees and reasemble the servo. Install and it should work great. Had to pull mine out and adjust the arm back just slightly. Sorry i didnt take pictures but mine is working flawless now. If you dont feel comfortable doing it i could possibly do it for you for a nominal fee plus shipping. Hope this helps someone fix theirs. If i do another one i will post pictures.
LC REAR WITH TUNDRA FRONT LIFT SKY JACKER M95 SHOCKS, 285 75 16 GRABBERS, 8.5 WHEELS WITH -25TH OFFSET, YAKIMA RACK
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
baskelh is offline   Reply With QuoteReply With Quote
Old 02-09-2014, 11:50 PM #2
baskelh's Avatar
baskelh's Avatar
The gold brush connectors are on the gear itself. Forgot the say that. Whole project took me about 45 mins.
Anyone replaced their recirculation servo horsey 4th Gen T4Rs 28 08-13-2022 10:14 PM
Mode Damper Servo Sub Assembly JBReagan 4th Gen T4Rs 4 03-30-2015 06:34 PM
Still NO HEAT... after air mix servo change... Elcajon 3rd gen T4Rs 2 10-20-2013 12:46 AM
Cruise Servo '94 4-R SwiftRunner Classic T4Rs 1 05-19-2009 09:00 AM
A/C Servo? CLewis General Discussions 1 05-07-2008 09:06 PM
