Old 02-10-2014, 06:37 AM #1
YnotinCO YnotinCO is offline
YnotinCO is on a distinguished road
Just a Click, but no start
Hello. I have 1999 4Runner with the 3.4L, AT, that intermittently will not start when the key is turned. I hear the relay clicking each attempt, but no ignition. I have a new battery, new plugs, the plug wires, ignition coils checked out OK, have cleaned the wire contacts at both ends of the starter, battery. When it acts up, if I keep turning the key, trying to start it, it'll eventually start. I have found a couple times that when it will not ignite, if I put in reverse and let it move a bit, put it back in park, then it'll start. The truck has 361,000 + miles on it,, any thoughts?
YnotinCO is offline   Reply With QuoteReply With Quote
Old 02-10-2014, 07:45 AM #2
clemson4r clemson4r is offline
clemson4r is on a distinguished road
Sounds like your starter needs replacing/rebuilding. This is a relatively common problem. I just rebuilt mine (new plunger, magnet, contacts, etc) for ~$55 using OEM parts. Much less expensive than purchasing a new OEM starter and much better quality than the AutoZone brand reman's.
Max
clemson4r is offline   Reply With QuoteReply With Quote
Old 02-10-2014, 10:16 AM #3
Semper_Fi's Avatar
Semper_Fi Semper_Fi is offline
Semper_Fi is on a distinguished road
Semper_Fi's Avatar
Max
x2 sounds like an easy fix, now if its turning over and not firing up I would check camshaft sensor and crankshaft sensor, I jus replaced mine. it would turn over but not start with that problem
98 Limited
Roof Rack
3" Toytec lift
33" Nitto Grapplers w spare
Craiger simulated bead lock wheels
Semper_Fi is offline   Reply With QuoteReply With Quote
Old 02-10-2014, 02:28 PM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
You do NOT need a new starter. Trading in a factory Denso to get a crap reman is a sin.
All you need to do is replace the starter contacts, easy to do once you go through the pain in the butt to remove the starter.
I have a link for that:
(Another) Starter Contacts Removal Thread!
My Backyard Frame Swap
Old 02-10-2014, 03:18 PM #5
PNW yota's Avatar
PNW yota PNW yota is offline
PNW yota is on a distinguished road
PNW yota's Avatar
Double check all your grounds too. Starter may be fine.
2000 Limited: Multi-mode (VF3AM), E-locker, TRD SC & exhaust, URD 7th injector, AIC/Timing Calibrator, Denso IK22, AT bypass, onboard air with rear bags, Tundra brakes. Hella 500FF. CB. Full weathertechs. '02 fascia upgrades, GaugePodx2 w/ boost+Aeroforce, Sport hood.
PNW yota is offline   Reply With QuoteReply With Quote
Old 02-10-2014, 05:39 PM #6
hrt4me hrt4me is offline
hrt4me is on a distinguished road
all you need is this $12 kit from Amazon: Denso starter repair kit (consists of the plunger and replacement contacts)
Be very careful about trying to start too often, because as your plunger wears into the contacts, it could potentially stick in the worn groove and cause a fire! Dave noted the following via his DIY write-up on the ExPo forums, Denso starter contact replacement:
Notice that the contacts are worn down and pitted. The major failure can and has been that the contacts get worn to the point that when the starter engages, the plunger will stick between the channels dug out of the contacts, keeping the starter engaged, even if you remove the key from the ignition!! There is full battery amperage going through the motor, and if this happens, then you run a great risk of your vehicle catching fire. That is why it is important to address this issue as soon as you start to get the starter "click".
hrt4me is offline   Reply With QuoteReply With Quote
Old 02-10-2014, 09:21 PM #7
TheDurk's Avatar
TheDurk's Avatar
That's the same kit I used. For the record, I have the smaller Denso starter used on most 5-speed V6 3G 4Runners without a special cold weather package.
Old 02-11-2014, 12:35 AM #8
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
this.... do this
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Old 02-11-2014, 04:08 AM #9
White 4x4runner's Avatar
White 4x4runner White 4x4runner is offline
White 4x4runner is on a distinguished road
Lies... I replaced my contacts and plunger with all Oem parts from toyota dealership. Less than a month later the bearing on the spindle blew apart. No replacing that. I've had an O' Rieley's in my car for almost 2 years now and its running solid.
2001 4runner sr5 4wheel drive
White 4x4runner is offline   Reply With QuoteReply With Quote
Old 02-11-2014, 07:10 AM #10
Originally Posted by White 4x4runner View Post
I replaced my contacts and plunger with all Oem parts from toyota dealership. Less than a month later the bearing on the spindle blew apart. No replacing that. I've had an O' Reiley's in my car for almost 2 years now and it's running solid.
what, if any, were your symptoms leading up to that?
Old 02-11-2014, 03:18 PM #11
TheDurk's Avatar
TheDurk's Avatar
Was that a factory Denso??
'Lies' is harsh. For most people, what I said is the truth and I stand by my advice.
Old 02-13-2014, 02:35 AM #12
i don't remember really. it was still working fine just making unusual noises. then it just stopped working and didn't even click.
Old 02-13-2014, 02:37 AM #13
factory starter with 200k on it. and sayin to trade it in is a sin may be your and some others judgment but in my case it would have saved me allot of the headache of doing the job twice. i do still agree with changing the contacts first then if you have problems trade it in for a reman.
Old 02-13-2014, 12:14 PM #14
TheDurk's Avatar
TheDurk's Avatar
Well, that's what I meant--the sin is trading a good Denso when a contact change was all it needed.
99 won't start, no click Gospinn 3rd gen T4Rs 37 07-20-2021 11:16 AM
Won't start - one click Bugsy 3rd gen T4Rs 29 02-25-2020 03:18 PM
2003 V6 Won't Start - One click and that's it 66Mhz 4th Gen T4Rs 17 12-07-2013 10:24 PM
Click sound when trying to start CAN-03runner Maintenance/Detailing 0 01-24-2012 04:50 PM
Starter Click, Click, Click. Jump starts immediately??? daugherty83 3rd gen T4Rs 17 09-18-2009 03:46 AM
