Old 02-10-2014, 07:44 PM #1
kmiller93's Avatar
kmiller93 kmiller93 is offline
Real Name: Kyle
kmiller93 is on a distinguished road
kmiller93's Avatar
Real Name: Kyle
Calipers stuck in mornings then drives fine.
Every morning lately when I put my truck into drive it doesn't move, I give it a little gas "pop" (from what sounds like the front brakes releasing) then every things fine and it drives like normal. My brake fluid is at the min but is still clear.
Does anyone have any ideas of what it could be?
89 S13 240sx IG SR_Hatch
01 T4R Sport 4wd
http://www.toyota-4runner.org/3rd-ge...ead-2-0-a.html
kmiller93 is offline   Reply With QuoteReply With Quote
Old 02-10-2014, 08:05 PM #2
blizz86's Avatar
blizz86 blizz86 is offline
Real Name: Brian - 20
blizz86 is on a distinguished road
blizz86's Avatar
try bleeding them. if anything its a cheap option. it could need a rebuild
2000 Limited 4x2 Build - OME lift // Tundra Brake Upgrade // Wet Okole // 265/70/16 Michelin X Radial LT2 // 3" FXR + 50 w Morimoto 5k // 1.25" Spidertraxx 4 corners
2012 SR5 4x4 [Magnetic Gray]: Stock suspension // OPOR TE sliders (trimmed rocker panels) // Husky Mudguards // CMG Roof Rack
blizz86 is offline   Reply With QuoteReply With Quote
Old 02-10-2014, 08:26 PM #3
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
I have no idea what the weather is like there, but does it park outside? any ice/snow?
mine has down that a few times the last few days also, the tires were frozen to the ground.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 02-10-2014, 09:11 PM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Are you sure it's the fronts? Do you use the e-brake? It sounds like what happens when the bellcranks on the e-brake cable freeze up in the rears. To rule it out, try not using the e-brake.
My Backyard Frame Swap
Old 02-10-2014, 10:23 PM #5
kmiller93's Avatar
Real Name: Kyle
kmiller93's Avatar
Real Name: Kyle
It is cold outside and thats when this started. Also I do use my e-brake but I'm almost sure its the fronts that pop. Ive had the rears stick before but I fixed that a while back.
01 T4R Sport 4wd
Old 02-11-2014, 12:24 AM #6
nissanh nissanh is offline
Do you have OEM brake pads? Some aftermarket ones can make this sound.
Old 02-11-2014, 12:53 AM #7
nevada's Avatar
nevada's Avatar
I still think its your tires freezing to the ground. try parking with some small sections of dry cardboard under your tires, and see if it still happens.
because stuck calipers don't release like that. and generally, when they are stuck, they stay stuck, and get tighter the more you use them.
3rd ten , brake calipers , calipers , issue , stuck
Won't start on cold mornings Bonedale 3rd gen T4Rs 28 01-22-2014 12:44 PM
Drives fine, then after 4-5 miles it starts shaking / idling low ???? combatmedic 3rd gen T4Rs 8 03-06-2012 12:49 AM
Cold mornings = Bumpy ride Brutus 3rd gen T4Rs 0 01-04-2011 09:56 PM
Tranny Stuck in 1st gear until its warm. Then its fine Grey Maintenance/Detailing 0 10-24-2010 04:04 AM
rough starts on cold mornings Big Norm Classic T4Rs 12 11-22-2008 10:48 PM
