Old 02-18-2014, 06:51 PM #1
TannerW's Avatar
TannerW TannerW is offline
Real Name: Tanner
TannerW is on a distinguished road
TannerW's Avatar
Real Name: Tanner
Replacing Blinker Switch
Hello. I had a couple people ask me to take a few pictures while replacing my turn signal switch so here they are.
The only tools needed were a phillps head screwdriver and a 10mm socket. I also used an extension to make it a bit easier.
First you have to remove the 4 bolts holding the plastic piece under the steering wheel.
Replacing Blinker Switch-dsc04406-jpg
After you have those remove you can pull down with a little force and pop it down like this.
Replacing Blinker Switch-dsc04417-jpg
Once you have that done there are two screws on either side of the steering wheel. You have to turn the steering wheel to get to them. There is also another screw under the steering wheel.
Replacing Blinker Switch-dsc04409-jpg
Replacing Blinker Switch-dsc04412-jpg
If you pry where the top and bottom of that piece meet you can pop it apart. You might need to use a flat head to help.
Replacing Blinker Switch-dsc04418-jpg
After you have those apart it will look like this.
Replacing Blinker Switch-dsc04419-jpg
Next you want to use your phillips head to unscrew the two screws holding the switch in. You have to also unplug the connector at the bottom.
Replacing Blinker Switch-dsc04420-jpg
It will slide out.
Replacing Blinker Switch-dsc04421-jpg
Once you have it out just do these steps backwards putting your new blinker switch in. Don't forget to plug the connector into your new switch. Test everything before putting it back together.
Thanks for reading and I hope this helped a few people out.
1996 V6 SR5 260k
2006 V6 SR5 150k
TannerW is offline   Reply With QuoteReply With Quote
blinker , switch
How to replace Headlight/Blinker Combo Switch capt ike 4th Gen T4Rs 3 05-01-2013 04:34 PM
Does Toyota recommend replacing the TB tensioner when replacing the TB? tsonnenl 4th Gen T4Rs 2 03-16-2012 10:34 AM
Replacing headlight switch Nubie4Runner Problems & Warranty Issues 7 02-28-2011 11:10 AM
Replacing the brake light switch (relay) apj 3rd gen T4Rs 0 11-30-2010 10:49 AM
4Runner: LED Blinker moved to Aux, Driving light installed in Blinker spot KU_MechE 3rd gen T4Rs 0 09-24-2006 05:31 AM
