In this same vain, are there any companies that make uprated swaybars. And no, I'm not trying to make a track monster, just something that will improve the ride, roll in the corners.
There is NO need to buy a "stronger" swaybar.
And BTW I highly doubt how much stronger that aftermarket one really is.
I've taken off my front sway bar to repaint it and trust me it is SOLID STEEL.
I've been wheeling my truck for over 10 years, personally, this same exact truck, and I can tell you my sway bar has never been bent the slightest bit.
In fact I can assure you that the sway bar mounts would probably sheer off the frame or the links would break before the bar would bend significantly.
If anything you will want to buy stronger 1" extended front sway bar links. You should be able to find them for $100 - $150 / pair.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish
treasonous thief.
