Originally Posted by TheKorstjens
Ok. Thanks for the input. Blunt but makes sense. I got the 88p because of what it would do especially for bigger tires. I guess if my only option is keeping the clamps that is what I will do. What is your opinion for wiring it straight into the battery and mounting in the truck? Would running wires to the cargo area be too far resistance wise? Again thanks for any help
Depending on the current the motor draws, it may be too far of a run and reduce the air output, as well as be a hazard if the wires get too hot. I'm sure there are online calculators for calculating wire gauge with a specified run.
If you're going to go far enough to wire a compressor into your truck, you may want to look into getting a compressor with a %100 duty cycle. If you're using this to air up after wheeling or something, it'll take a long time. I air up my 33s from 15 psi with a 100% duty cycle viair pump (480C) and it still takes 15-20 minutes. If it's just for topping off or emergencies, completely disregard that.
