Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 03-11-2014, 10:13 PM #16
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Originally Posted by merlin12 View Post
how did the plastydip smoke work for you? i like what you have done and am thinking about blacking out some of my lights now
>>>it worked out ok. I'm not thrilled with it. i put it on too heavy. looks decent, i'd say a 5 out of 10. so nothing special but it was cheap.
Originally Posted by BLUE RUNNER View Post
Did you find an ARB bumper yet?
An ARB painted silver would look great on your 4Runner.
>>> i haven't yet mostly because of funds. but i had a black taco ARB on my last 4runner and i like the power coated black a lot.
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 01:22 PM #17
nor_cal51501 nor_cal51501 is offline
Real Name: Shane
nor_cal51501 is on a distinguished road
Real Name: Shane
Originally Posted by infamousRNR View Post
sounds great! but my bypass that i made for the dvd player didn't end up working ...
does anyone have any ideas why it wouldn't?
i used a 12v relay.
BLUE REMOTE WIRE --- 85 ON RELAY
GREEN HANDBRAKE WIRE -- 30 ON RELAY
BLACK GROUND WIRE -- 86 ON RELAY ALSO ATTACHED TO 87..
used a wiring harness that i got from ebay for toyota's so i didn't have to splice any factory wiring.
1987 - 2012 Toyota 4Runner Radio Wiring Harness Adapter #1761
1987 2012 Toyota 4Runner Radio Wiring Harness Adapter 1761 | eBay
Most of the new double dins aren't constant ground detection, all you need is a momentary ground switch. BUTTTT I can't say for sure on that deck, most either need a ground constant to simulate parking brake switch continuity or I had a double din before that needed only a momentary ground.
'01 Sport: E-locked, 285/70/17's, TURD S/C, 200k club
My Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
nor_cal51501 is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 11:58 PM #18
minuscule update
bought a pair of rear flares/mud flaps to practice on, so i don't mess up my originals on the car already.
i found that scissors starting both sides works best for the curved part, then a utility knife. then i tried to sand any rough edges.
InfamousRNR's 2002 Limited BU!LD THREAD-img_1043-jpg  InfamousRNR's 2002 Limited BU!LD THREAD-img_1044-jpg
Build Thread
Old 04-04-2014, 01:26 AM #19
Roof Racks
bought some roof racks from this site to fill the void my car was missing. the owner i bought it from removed the racks...
my ultimate goal is to fab up some mounts for a safari rack (a Rola Roof Rack) for a low profile look that hugs the roof close, line-x the entire thing and keep the rails that touch the runner's top... so 6 cross rails should look sick over the standard 3, but evenly spaced across the roof... not like the picture
.some advice when taking of the roof rail caps... super hard to get back on. to make it super easy i recommend taking the whole roof off, or simply loosening the entire rail to lift it up a bit to fit the cap back on the end...
InfamousRNR's 2002 Limited BU!LD THREAD-img_1055-jpg
Build Thread
Old 04-11-2014, 11:03 PM #20
ARB Bumper Installation
first off THANKS @nor_cal51501
without him i would have never done any of this!
InfamousRNR's 2002 Limited BU!LD THREAD-img_1085-jpg  InfamousRNR's 2002 Limited BU!LD THREAD-img_1084-jpg  InfamousRNR's 2002 Limited BU!LD THREAD-img_1082-jpg
Build Thread
Old 04-12-2014, 12:09 PM #21
Real Name: Shane
Real Name: Shane
No problem bud, it turned out pretty damn sweet. Those ARB instructions sucked soo bad. Whomever wrote out the instructions needs to be fired or punched in the face for doing a shit job, otherwise it was a good day.
Old 04-12-2014, 12:51 PM #22
Time Lapse GoPro Video
put together a little time lapse video that shows the progress of our work on installing the ARB Bumper... hope you like red boxers
Build Thread
Old 04-13-2014, 12:28 AM #23
Real Name: Shane
Real Name: Shane
Duuuuuude!!! That time lapse vid was legit!!
1. Awesome that you kept the part where I kick over the camera, then have the lense right in my face going "oops" lol
2. That was hilarious seeing the process and thinking back, "**** the instruction person".
3. Anyone installing an ARB bumper is better served figuring that shot out themselves and burning the instructions. They are completely useless, confusing and illegible to anyone with a brain. The author of the instructions would do well to shoot themselves in the face.
That's all for now, glad you like it. Makes your rig look beast mode for sure!!
Old 04-21-2014, 11:35 PM #24
Tinted Front Side Windows
bought an extra set of driver and passenger glass from a junk yard as the previous owner of the vehicle scratched the windows badly with something abrasive. made a time lapse video of the process of removing and installing a glass window to the drivers side. i tinted the glass before installation.
basic tools needed:
10mm socket
phillips screw driver
TIP TO REMOVING GLASS/REPLACING GLASS:
put the window at an angle, dipping the glass forward in the door, and lifting it out at a 90 degree angle upwards.
Build Thread
Old 04-21-2014, 11:40 PM #25
Tinted front windows
20% all around now. i believe the factory privacy glass is 20%. . . .
InfamousRNR's 2002 Limited BU!LD THREAD-img_1168-jpg
Build Thread
Old 04-21-2014, 11:56 PM #26
Real Name: Shane
Real Name: Shane
I still think your windows look way darker than my factory tint. We should probably just trade windows for a while to make sure.... Yes?
Old 04-23-2014, 01:03 AM #27
Installed antenna adapters and bluetooth mic
so while i was installing my pioneer avh-x4600bt i forgot to connect my bluetooth microphone for hands free dialing, so while waiting for work i ripped apart my dash in the parking lot and connected my BT wire and my antenna adapters.
i picked up an adapter from amazon.com for an adapter that ties our 2 antenna's into 1 single connection so it can go directly into the back of the pioneer stereo head unit.
(1) adapter from the rear one which is smaller... and (1) adapter to tie the two antenna connections into one...
for those of you wanting to keep your factory harness intact and away from splicing......pick up the wire adapter harness designed to plug in directly into toyota stereo's from 1987 - current year to prevent you from cutting up your nice OEM harness
AMAZON gives you nice option to buy all 3 at once...however here they are separately
Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker
Metra 40-UV43 Male to Female Motorola Antenna Cable
Scosche Mda-B Micro/Delco Antenna Adapter Tip
picture shows mounting/clipping location of my microphone for the handsfree bluetooth. reception and quality of sound are perfect and mic is not blocked...
didn't want a permanent mounting location... the mounting clip that it came with worked perfect to attach to where the steering wheel comes out of.
InfamousRNR's 2002 Limited BU!LD THREAD-img_1174-jpg  InfamousRNR's 2002 Limited BU!LD THREAD-img_1175-jpg
Build Thread
Old 04-23-2014, 01:07 AM #28
Real Name: Shane
Real Name: Shane
Slow, but sure progress. Keep it going!! Diff breather mod soon!!
Old 04-26-2014, 01:12 PM #29
cops went n' gone dun me dirty
was leaving work the other night and got pulled over.
my passengers side headlamp went out, must have went out literally in front of a cop because it was fine when i left work. guess I'm just lucky like that.
anyways got a generic bulb from O'Reily Auto parts.
does anyone have any opinions on this bulb brand?
what is the OEM brand of bulb for our headlights?
InfamousRNR's 2002 Limited BU!LD THREAD-img_1180-jpg  InfamousRNR's 2002 Limited BU!LD THREAD-img_1184-jpg
Build Thread
Old 04-26-2014, 02:11 PM #30
Dementedfish's Avatar
Dementedfish Dementedfish is offline
Dementedfish is on a distinguished road
Am I the only one who noticed the beer in the cupholder? haha
Dementedfish is offline   Reply With QuoteReply With Quote
3GT4R's Build Thread 2002 4Runner 3GT4R 3rd gen T4Rs 53 08-06-2017 01:17 PM
My Build Thread - 2002 Gold Runner ALBPM 3rd gen T4Rs 31 11-09-2015 05:32 PM
Chrisdowling84's 2002 Build Thread chrisdowling84 3rd gen T4Rs 35 02-16-2015 11:44 AM
2002tii's 2002 4Runner Sport Edition 4WD thread 2002tii 3rd gen T4Rs 25 03-08-2014 10:41 AM
mikebontoft's BMW 2002 build thread mikebontoft All Other Vehicles 14 03-04-2014 10:48 PM
